Showing results forĀ
Search instead forĀ
Did you mean:Ā
SG500-52-K9-NA Random Reboots
jbpollard
Not sure what's causing it but every once and awhile all the ports go down and its like the switch reboots. In the logs I can see is the switch saying all the vlan's and port group are down and then they come back online. Anyone know what causes this I'm on Version 1.3.0.62 firmware.
Whats the easiest way to turn off the native vlan mismatches?
Here's the log
2147474669 2016-Feb-15 16:12:35 Informational %LINK-I-Up: Vlan 400
2147474670 2016-Feb-15 16:12:35 Informational %LINK-I-Up: Vlan 300
2147474671 2016-Feb-15 16:12:35 Informational %LINK-I-Up: Vlan 200
2147474672 2016-Feb-15 16:12:34 Informational %LINK-I-Up: Vlan 1
2147474673 2016-Feb-15 16:12:34 Warning %CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi1/1/49.
2147474674 2016-Feb-15 16:12:00 Warning %STP-W-PORTSTATUS: Po1: STP status Forwarding
2147474675 2016-Feb-15 16:11:30 Informational %LINK-I-Up: gi1/1/50
2147474676 2016-Feb-15 16:11:30 Informational %TRUNK-I-PORTADDED: Port gi1/1/50 added to Po1
2147474677 2016-Feb-15 16:11:30 Informational %LINK-I-Up: Po1, aggregated (1)
2147474678 2016-Feb-15 16:11:30 Informational %LINK-I-Up: gi1/1/49, aggregated (1)
2147474679 2016-Feb-15 16:11:30 Informational %TRUNK-I-PORTADDED: Port gi1/1/49 added to Po1, aggregated (1)
2147474680 2016-Feb-15 16:11:27 Warning %LINK-W-Down: Po1
2147474681 2016-Feb-15 16:11:27 Warning %LINK-W-Down: gi1/1/49
2147474682 2016-Feb-15 16:11:27 Warning %TRUNK-W-PORTDOWN: Port gi1/1/49 removed from Po1: port is down/notPresent
2147474683 2016-Feb-15 16:11:27 Warning %LINK-W-Down: gi1/1/50, aggregated (1)
2147474684 2016-Feb-15 16:11:27 Warning %TRUNK-W-PORTDOWN: Port gi1/1/50 removed from Po1: port is down/notPresent
2147474685 2016-Feb-15 16:11:22 Warning %STP-W-PORTSTATUS: Po1: STP status Forwarding
2147474686 2016-Feb-15 16:11:18 Informational %LINK-I-Up: Po1
2147474687 2016-Feb-15 16:11:18 Informational %LINK-I-Up: gi1/1/50
2147474688 2016-Feb-15 16:11:18 Informational %LINK-I-Up: gi1/1/49, aggregated (1)
2147474689 2016-Feb-15 16:11:18 Informational %TRUNK-I-PORTADDED: Port gi1/1/49 added to Po1, aggregated (1)
2147474690 2016-Feb-15 16:11:18 Informational %TRUNK-I-PORTADDED: Port gi1/1/50 added to Po1
2147474691 2016-Feb-15 16:11:15 Warning %LINK-W-Down: Po1
2147474692 2016-Feb-15 16:11:15 Warning %LINK-W-Down: gi1/1/50
2147474693 2016-Feb-15 16:11:15 Warning %LINK-W-Down: gi1/1/49, aggregated (1)
2147474694 2016-Feb-15 16:11:15 Warning %TRUNK-W-PORTDOWN: Port gi1/1/49 removed from Po1: port is down/notPresent, aggregated (1)
2147474695 2016-Feb-15 16:11:15 Warning %TRUNK-W-PORTDOWN: Port gi1/1/50 removed from Po1: port is down/notPresent
2147474696 2016-Feb-15 16:11:13 Warning %STP-W-PORTSTATUS: Po1: STP status Forwarding
2147474697 2016-Feb-15 16:11:09 Informational %LINK-I-Up: gi1/1/49
2147474698 2016-Feb-15 16:11:09 Informational %TRUNK-I-PORTADDED: Port gi1/1/49 added to Po1
2147474699 2016-Feb-15 16:11:09 Informational %LINK-I-Up: Po1, aggregated (1)
2147474700 2016-Feb-15 16:11:09 Informational %LINK-I-Up: gi1/1/50, aggregated (1)
2147474701 2016-Feb-15 16:11:08 Informational %TRUNK-I-PORTADDED: Port gi1/1/50 added to Po1, aggregated (1)
2147474702 2016-Feb-15 16:11:06 Warning %LINK-W-Down: Po1
2147474703 2016-Feb-15 16:11:06 Warning %LINK-W-Down: gi1/1/49
2147474704 2016-Feb-15 16:11:06 Warning %TRUNK-W-PORTDOWN: Port gi1/1/49 removed from Po1: port is down/notPresent
2147474705 2016-Feb-15 16:11:06 Warning %LINK-W-Down: gi1/1/50
2147474721 2016-Feb-15 16:10:07 Warning %TRUNK-W-PORTDOWN: Port gi1/1/49 removed from Po1: port is down/notPresent
2147474722 2016-Feb-15 16:09:36 Warning %CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi1/1/50.
2147474723 2016-Feb-15 16:09:36 Warning %CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi1/1/24.
jbpollard
Earlier log
2147474796 2016-Feb-15 13:09:34 Informational %LINK-I-Up: Vlan 400
2147474797 2016-Feb-15 13:09:34 Informational %LINK-I-Up: Vlan 300
2147474798 2016-Feb-15 13:09:34 Informational %LINK-I-Up: Vlan 200
2147474799 2016-Feb-15 13:09:34 Informational %LINK-I-Up: Vlan 1
2147474800 2016-Feb-15 13:09:34 Warning %CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi1/1/50.
2147474801 2016-Feb-15 13:09:32 Warning %CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi1/1/24.
2147474802 2016-Feb-15 13:08:40 Warning %STP-W-PORTSTATUS: Po1: STP status Forwarding
2147474803 2016-Feb-15 13:08:10 Informational %LINK-I-Up: gi1/1/49
2147474804 2016-Feb-15 13:08:10 Informational %TRUNK-I-PORTADDED: Port gi1/1/49 added to Po1
2147474805 2016-Feb-15 13:08:10 Informational %LINK-I-Up: Po1
2147474806 2016-Feb-15 13:08:10 Informational %LINK-I-Up: gi1/1/50
2147474807 2016-Feb-15 13:08:10 Informational %TRUNK-I-PORTADDED: Port gi1/1/50 added to Po1
2147474808 2016-Feb-15 13:08:07 Warning %LINK-W-Down: Po1
2147474809 2016-Feb-15 13:08:07 Warning %LINK-W-Down: gi1/1/49
2147474810 2016-Feb-15 13:08:07 Warning %TRUNK-W-PORTDOWN: Port gi1/1/49 removed from Po1: port is down/notPresent
2147474811 2016-Feb-15 13:08:07 Warning %LINK-W-Down: gi1/1/50, aggregated (1)
2147474812 2016-Feb-15 13:08:07 Warning %TRUNK-W-PORTDOWN: Port gi1/1/50 removed from Po1: port is down/notPresent
2147474813 2016-Feb-15 13:08:03 Warning %STP-W-PORTSTATUS: Po1: STP status Forwarding
2147474814 2016-Feb-15 13:07:58 Informational %LINK-I-Up: gi1/1/49
2147474815 2016-Feb-15 13:07:58 Informational %TRUNK-I-PORTADDED: Port gi1/1/49 added to Po1
2147474816 2016-Feb-15 13:07:58 Informational %LINK-I-Up: Po1
2147474817 2016-Feb-15 13:07:58 Informational %LINK-I-Up: gi1/1/50
2147474818 2016-Feb-15 13:07:58 Informational %TRUNK-I-PORTADDED: Port gi1/1/50 added to Po1
2147474819 2016-Feb-15 13:07:55 Warning %LINK-W-Down: Po1
2147474820 2016-Feb-15 13:07:55 Warning %LINK-W-Down: gi1/1/50
2147474821 2016-Feb-15 13:07:55 Warning %LINK-W-Down: gi1/1/49, aggregated (1)
2147474822 2016-Feb-15 13:07:55 Warning %TRUNK-W-PORTDOWN: Port gi1/1/49 removed from Po1: port is down/notPresent, aggregated (1)
2147474823 2016-Feb-15 13:07:55 Warning %TRUNK-W-PORTDOWN: Port gi1/1/50 removed from Po1: port is down/notPresent
2147474824 2016-Feb-15 13:07:53 Warning %STP-W-PORTSTATUS: Po1: STP status Forwarding
2147474825 2016-Feb-15 13:07:49 Informational %LINK-I-Up: gi1/1/49
2147474826 2016-Feb-15 13:07:49 Informational %TRUNK-I-PORTADDED: Port gi1/1/49 added to Po1
2147474827 2016-Feb-15 13:07:49 Informational %LINK-I-Up: Po1
2147474828 2016-Feb-15 13:07:49 Informational %LINK-I-Up: gi1/1/50
2147474829 2016-Feb-15 13:07:49 Informational %TRUNK-I-PORTADDED: Port gi1/1/50 added to Po1
2147474830 2016-Feb-15 13:07:46 Warning %LINK-W-Down: Po1
2147474831 2016-Feb-15 13:07:46 Warning %LINK-W-Down: gi1/1/49
2147474832 2016-Feb-15 13:07:46 Warning %TRUNK-W-PORTDOWN: Port gi1/1/49 removed from Po1: port is down/notPresent
2147474833 2016-Feb-15 13:07:46 Warning %LINK-W-Down: gi1/1/50
2147474834 2016-Feb-15 13:07:46 Warning %TRUNK-W-PORTDOWN: Port gi1/1/50 removed from Po1: port is down/notPresent
2147474835 2016-Feb-15 13:06:54 Warning %STP-W-PORTSTATUS: Po1: STP status Forwarding
2147474836 2016-Feb-15 13:06:50 Informational %LINK-I-Up: gi1/1/49
2147474837 2016-Feb-15 13:06:50 Informational %TRUNK-I-PORTADDED: Port gi1/1/49 added to Po1
2147474838 2016-Feb-15 13:06:50 Informational %LINK-I-Up: Po1
2147474839 2016-Feb-15 13:06:50 Informational %LINK-I-Up: gi1/1/50
2147474840 2016-Feb-15 13:06:50 Informational %TRUNK-I-PORTADDED: Port gi1/1/50 added to Po1
2147474841 2016-Feb-15 13:06:47 Warning %LINK-W-Down: Vlan 400
2147474842 2016-Feb-15 13:06:47 Warning %LINK-W-Down: Vlan 300
2147474843 2016-Feb-15 13:06:47 Warning %LINK-W-Down: Vlan 200
2147474844 2016-Feb-15 13:06:47 Warning %LINK-W-Down: Vlan 1
2147474845 2016-Feb-15 13:06:47 Warning %LINK-W-Down: Po1
2147474846 2016-Feb-15 13:06:47 Warning %LINK-W-Down: gi1/1/50
2147474847 2016-Feb-15 13:06:47 Warning %LINK-W-Down: gi1/1/49
Updated firmware and bootcode seemed to resolve the issue.
