06-15-2015 11:08 AM
we are getting following OID in SNMP, which we do not find:
1.3.6.1.4.1.9.6.1.101.0.151
We can find 1.3.6.1.4.1.9.6.1.101.0 but no further objects in there. So maybe there are more, that do not work
Is there someone who could tell me, where to find them ?
best regards
Axel
06-16-2015 01:54 AM
just for curiosity - what information should be stored in that OID? Or whats the object name of that OID?
06-16-2015 02:05 AM
This is our Problem. we get this OID via SNMP Trap into the Management System, which then says, that this is not defined.
What I could find so far is:
06-16-2015 04:11 AM
Ah, understand, that's TRAP OID your receiving. It should be assigned to "STP status Forwarding" event mapped to port. Especially this one:
rldot1dStpPortStateForwarding NOTIFICATION-TYPE OBJECTS { rndErrorDesc, rndErrorSeverity, rldot1dStpTrapVrblifIndex, rldot1dStpTrapVrblVID } STATUS current DESCRIPTION "The trap is sent by a bridge when any of its configured ports transitions from the Learning state to the Forwarding state." ::= { rndNotifications 151 }
Cisco SNMP Object Navigator is not very useful in case of Cisco SMB class. It is rather useful for Enterprise class devices.
There is MIB available for your switch to download. It contains MIB definitions of all traps and MIB OIDs used by SG switches. If your NMS support importing those MIBs, then I suggest you to import them all.
Traps are located in dedicated file "CISCOSB-traps-mib.mib" but they have only represented by name, not by OIDs.
06-16-2015 04:36 AM
Hi Michael,
meanwhile I got the Info to update the Switches to the latest Firmware and also update the MIB and load them to the Management System.
I hope this will solve the Problem.
best regards
Axel
