There is no "Switchport Voice Vlan" command on SF300-24P !!!
CSCO11068191
Hello everyone
I am in an urgent problem :S
I have a Small Business SF300-24P
I have created two vlans one data and one voice
but i have not assigned them to the ports and I am not sure how to do so since there's no "switchport voice vlan" command under the interface !!
here are the configurations
btw the switchport mode is still trunk as it is by default
Thanks in advance
switch0a1172#
switch0a1172#
switch0a1172#sho run
config-file-header
switch0a1172
v1.2.9.44 / R750_NIK_1_2_584_002
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 13,20
exit
voice vlan id 20
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
hostname switch0a1172
username cisco password encrypted c8e383b1dd7be99f878a387d87766e875404e0b3 priv
lege 15
ip telnet server
interface vlan 13
name "VLAN13"
interface vlan 20
name VOICE
switch0a1172#
It does automatically through the auto smart port based off external trigger by default. CDP and LLDP enable devices are supported.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
5 Replies 5
Tom Watts
config t
voice vlan id 20
-Tom
it's already there bro
but how to assign data and voice vlan on ports
-Tom
tech.linkwave
interface vlan 13
name "VLAN13"
interface vlan 20
name VOICE
Both are vlans, not voice vlans.....
Sandy
Hi Sandy,
You need:
switchxxxxxx(config)# voice vlan id 20
and smart ports should do the rest.
for your reference: http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/CLI_300.pdf?mdfid=283019666
Aleksandra
