02-24-2015 11:55 AM - edited 03-07-2019 10:49 PM
Hello can someone confirm whether LAN Base image will allow me to configure 10 SVIs, with inter vlan routing and a static default route pointing to my ASA which I will have connected to a /30 on SVI 800 (for example)?
I know the documentation shows that the following:
Solved! Go to Solution.
02-26-2015 02:52 AM
Yes. They are correct. LAN Base, with default SDM Template, will support only 16 static routes. But if you want routing protocols, only IP Base feature set is required.
02-24-2015 12:59 PM
Nope. If you want routing, then IP Base is the minimum and not all routing protocols are supported with just IP Base.
02-26-2015 01:00 AM
Thanks Leo... Have you tested this with new IOS ?
Now I am even more confused as i just got a reply from Cisco Partner Helpline saying that yes I can create SVIs and static routes with LAN base and point a static default route to an SVI..
Also, from the URL above:
Note On switches running the LAN base feature, static routing on VLANs is supported only with Cisco IOS Release 12.2(58)SE and later.
On swion switches running the LAN base feature set, IP static routing is supported only with the default sdm template. For more information on the SDM templates, see Chapter 1, “Configuring SDM Templates” or see the sdm prefer command in the command reference for this release.
02-26-2015 02:52 AM
02-27-2015 03:32 AM
Thanks Leo
