catalyst 3560x Device Credential Verification: FAIL
nianqing212
there is a C3650x-24 switch , then excute the 'show license status' command, have the following output, it's have an 'fail' keyword :Device Credential Verification: FAIL
I don'g understand what that's mean ?  can anyone tell me
thanks!
Switch#sh license status
              License Type Supported
       permanent  Non-expiring node locked license
       extension  Expiring node locked license
       evaluation Expiring non node locked license
              License Operation Supported
       install    Install license
       clear      Clear license
       annotate   Comment license
       save       Save license
       revoke     Revoke license
       call-home  License call-home
              Call-home Operation Supported
       show pak   Display license pak via call-home
       install    Install license via call-home
       revoke     Revoke license via call-home
       resend     Fetch license via call-home
              Device status
       Device Credential type: DEVICE
       Rehost Type: DC_OR_IC
9 Replies 9
smogra
Can you provide show ver for the device? and is this issue causing any problems on the switch?
this question is my customer email to me, It seems no other issue
Switch#sh ver
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 12.2(53)SE2, RELEASE SOFTWARE (f
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 21-Apr-10 04:26 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02400000
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560X-HBOOT-M) Version 12.2(53r)SE1, RELEASE SOFTWARE (fc1)
Switch uptime is 2 minutes
System image file is "flash:/c3560e-universalk9-mz.122-53.SE2/c3560e-universalk9-mz.122-53.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3560X-24 (PowerPC405) processor (revision A0) wi
*Mar  1 00:02:13.102: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
*Mar  1 00:02:13.102: %LINK-5-CHANGED: Interface FastEthernet0, changed state to administratively do
Processor board ID XXXXXX
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : XXXXXX
Motherboard assembly number     : XXXXXX
Motherboard serial number       : XXXXXX
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : WS-C3560X-24T-S
Daughterboard assembly number   : XXXXXX
Daughterboard serial number     : XXXXXX
System serial number            : XXXXXX
Top Assembly Part Number        : XXXXXX
Top Assembly Revision Number    : A0
Version ID                      : V01
CLEI Code Number                : XXXXXX
Hardware Board Revision Number  : 0x02
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3560X-24       12.2(53)SE2           C3560E-UNIVERSALK9-M
Configuration register is 0xF
Switch#
Switch#
       clear      Clear license
       save       Save license
              Device status
Thanks.
Was it like this since starting? Or you tried doing some changes to the device and ended up seeing like this?
Was an IOS upgrade done recently? Newer images has a new feature of autheticating the hardware. If it is a new device, I would suggest to contact your reseller. If not, please open a TAC case.
http://www.cisco.com/cisco/web/support/index.html
AJ.
I would also suggest to open a case with TAC.
any update on this issue.
I have faced the same issue with 4331 router.
hi
We are facing the same credential failure on ISR 4331. What did you do to resolve
Volgash
Hi everyone,
I have the same problem with ISR4331-SEC/K9 and WS-C3560CX-8PC-S. Does anybody know how to resolve it and what the reason is?
Thank You
nchristo222
also same issue. router feature sets all appear to work as well... frustrating...
