Cisco SG350XG-24F questions
quakch
Hi, I am looking at the Cisco SG350XG-24F 24-Port 10G SFP+ Stackable Managed Switch, planning to setup a LAN, with existing copper infrastructure and new fiber lines. May I know for this switch, can it support equipment running copper ethernet with 1Gbps (in 10G SFP+) ?
Also would like to confirm if both copper and fiber can run together in the switch without problem.
Else other recommendations are welcome
Thanks !
balaji.bandi
I have not tested, but as per the docs
The SFP+ slot supports 10G and 1G speeds.
BB
inderdeeps
Level 4
Level 4
Its been there you can use that and you will get 1 Gbps of speed on SFP+
The SFP+ slot supports 10G and 1G speeds which is tested and working.
Inderdeep Singh
www.thenetworkdna.com
quakch
Thanks BB & Inderdeep !
