08-31-2021 08:25 AM
Hello!
I want to setup multiple VLANs on single ports on two of my switches. I am doing this to separate our Staff / Guest internet access. I'm not sure if I set this up properly, but here is my setup:
Solved! Go to Solution.
08-31-2021 08:43 AM
Hello @cbcav ,
the proposed setup looks like correct there is only one aspect to investigate:
check the native VLAN default settings on the devices in most cases it is i VLAN1 and it is expected untagged.
in an 8021.Q a single VLAN can travel untagged and this is by default for most vendors VLAN 1.
Hope to help
Giuseppe
08-31-2021 08:43 AM
Hello @cbcav ,
Hope to help
Giuseppe
08-31-2021 09:01 AM
Thank you for the reply! VLAN1 is the default one on both switches, should I change VLAN1 to untagged for both? Also, I just found an article from Cisco's site, and the 'advanced mode' showed has a 'general' option for the VLANs. Would that be more ideal over trunk?
08-31-2021 02:56 PM
Always suggest to have native VLAN both the side same when you configuring trunk.
09-03-2021 03:00 PM - edited 09-03-2021 03:00 PM
So I'm stumped. On SW1 I am able to get both VLANs to work, but on SW2 I get APIPA, here is what I have setup:
SW1
SW2 First Attempt:
SW2 Attempt 2:
