02-27-2015 12:11 PM - edited 03-07-2019 10:53 PM
I configured 4500X management port (Fa1) and I can ping the IP from the network. But when I tried telnet to the port, the switch showed "password required but not set".
I didn't configure any password for VTY. Should it be equivalent to "no login"? If to set or change a password for the management port, where to configure it?
Thanks a lot
Solved! Go to Solution.
02-27-2015 01:04 PM
Yes, "password" and "login" for the management port should be configured under the "vty" lines.
Best regards,
Antonin
02-27-2015 01:04 PM
Best regards,
Antonin
