01-20-2022 01:58 AM
Hi There,
I am unable to configure SNMPv3 Privacy / Encryption in cisco WS-C3560G-48PS Switch, could you please share the CLI commands to execute this command OR does this switch module support SNMPV3 Privacy/Encryption method?
Logs:
SW02(config)#snmp-server user Abd ABC v3 AUTH SHA 12345 ?
access specify an access-list associated with this group
<cr>
Antony Xavier.
01-20-2022 03:21 AM
what is the version of code running, what License device has it :
check the below SNMP version and limitations and configuration :
01-26-2022 07:02 AM
Software version: 12.2(35)SE5
Model: WS-C3560G-48PS
SW Image: C3560-IPBASE-M
01-26-2022 04:26 PM
Check the command syntax :
01-20-2022 04:11 AM
what if you use md5 instead of sha ?
SW02(config)#snmp-server user Abd ABC v3 auth md5 12345 ?
01-26-2022 07:00 AM
Hi Georg,
No luck with Md5
SW02(config)#$ user Abd ABC v3 auth md5 12345 ?
<cr>
01-26-2022 02:28 PM - edited 01-26-2022 02:47 PM
Does this work?
ip access-list standard SNMP_ACCESS_ACL permit any ! snmp-server view ISO-ALL iso included ! snmp-server group MY-RO-GROUP v3 priv read ISO-ALL access SNMP_ACCESS_ACL snmp-server group MY-RW-GROUP v3 priv read ISO-ALL write ISO-ALL notify ISO-ALL access SNMP_ACCESS_ACL ! snmp-server user MY-USER1 MY-RO-GROUP v3 auth sha blablablabla priv aes 128 blablablabla snmp-server user MY-USER2 MY-RW-GROUP v3 auth sha blablablabla priv aes 128 blablablabla
If not, I'd make sure that there is a k9 somewhere in the ios filename.
Some of those older switches with very little space couldn't fit all the crypto-stuff in the ios.
If t hat's the case, try this instead.
permit any
snmp-server group MY-RO-GROUP v3 auth read ISO-ALL access SNMP_ACCESS_ACL
snmp-server group MY-RW-GROUP v3 auth read ISO-ALL write ISO-ALL notify ISO-ALL access SNMP_ACCESS_ACL
Let us know how it goes.
