3.5mm Input on the Quad Camera
Matt_W
Level 3
Level 3
Working with a reseller trying to use the Quad Camera connected to a cloud registered Room Kit Plus and would like to use it as a speaker bar to play music in the room when not in a call. Would like to use the 3.5mm audio input on the Camera for this. I've found some older discussions stating you can do this, but when I try connecting a 3.5mm stereo jack to this input I do not get any audio. Is there a setting somewhere to turn this on? Or, is this not an option when using the camera in this configuration?
AFAIK, audio input works when you are on a call. Never come across  a scenario using Cs kit as Music sound bar.
Response Signature
