02-10-2015 10:47 PM - edited 03-18-2019 04:00 AM
Dear all,
There is a new Be6k High density in the testing environment.
However, we don't have clear picture on the deploying VCS Core/edge with the CUCM in the BE6k.
Best Regards,
Ben Lai
Solved! Go to Solution.
02-11-2015 04:48 AM
1 Either works, you just need to make sure to properly design and configure the underlying network and the ports to which each VM will connect
2 There´s PLENTY of information on that
http://www.cisco.com/c/en/us/support/unified-communications/telepresence-video-communication-server-vcs/tsd-products-support-series-home.html
02-11-2015 04:48 AM
