Cisco endpoint to Scopia bridge
George Thomas
Level 10
Level 10
Hello!
Has anyone been successful in getting two way video working from an endpoint registered to VCS calling into a Scopia bridge using H323?
Thanks in advance!
Please rate useful posts.
Patrick McCarthy
My guess is the lack of responses here is due to this combination being fairly rare. That said, I'm sure it should work if everything is configured properly. Is there a firewall in the mix perhaps causing you problems? Looking at TC7.3.5 release notes Cisco does do interop testing with the Scopia Elite - you can see a note about BFCP not working (not an issue with H.323), so it is tested.
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/software/tc7/release_notes/tc-software-release-notes-tc7.pdf
