ā07-11-2012 10:41 PM - edited ā03-17-2019 11:27 PM
I want to creat search ruls on my VCSc and VCS ex to call this kind of format 111111@1.1.1.1 or 11111@uri
exactly i need to do to make thsi ruls on both vcs and VCS ex
Solved! Go to Solution.
ā07-14-2012 01:47 AM
Hello Mohamed!
This is a pretty standard deployment.
Please read through:
and configure your VCSs accordingly. It covers as well how to set up the VCSs for IP dialing as well as for DNS.
Martin
Mohamed: Please rate the answers using the stars below the messages!
ā07-16-2012 02:37 AM
I would guess what they want is a h.323 call to a gk/bk with a e164 id maybe Annex O.
Its two things, its dependent on your endpoint how it dials, on a former Tandberg endpoint
you would still dial number@ip (in your example 11111@1.1.1.1).
What kind of endpoint do you use?
What kind of changes did you do from the standard deployment?
Especially the ip dialing has to be followed which is indirect on the vcs-c and direct on the vcs-e.
Do other external calls via the VCSe work?
Could you post a screenshot of the search history of that call?
It is fine to have the VCS-E behind a firewall, only remember if you put it in a DMZ
and use an internal address and NAT it towards its external address then you need
a special option key and sure, the firewall also has to be configured correctly :-)
ā07-12-2012 03:34 AM
To make proper search rule, need a bit more information.
ā07-12-2012 04:08 AM
Thank you for your help
I have here endpoint (H323 and SIP) and MCU registered to VCS-C and there is VCS-E behind fire wall.
First I needed to call far end (have polycom system) with 111##1.1.1.1
Which didnāt work so they ask me to call 111@1.1.1.1 which should work if I have the right rules .
Yes Iām expect to receive the call from external device (not register on VCS-C or VCS-E) with xxx@
VCS-E
VCS-C
Thx
ā07-13-2012 11:17 PM
"there is VCS-E behind fire wall."
You would normally have the VCS-C behind the firewall and the VCS-E outside the firewall, either in DMZ or in public as the whole point is to provide secure firewall traversal, something you won't get if you have both behind the firewall.
/jens
Hello Mohamed!
Martin
ā07-16-2012 01:13 AM
Thanks jens for reply we have to keep it behind firewall for security reason.
Hi Martin thank you for share the document with me.i actually look at it before.and we had to change from the setting
mentioned in the document to meet some our requirement .
I contact the far side to confirm the dialing format again because I tried it with standalone machine and also it didnāt work.
But they ask me to stick with this format
IP##Ext
1.1.1.1##11111
I tried from standalone machine and its working but when I tried from end point registered to the gatekeeper didnāt work.
ā07-16-2012 03:22 AM
IP_address##Alias is Polycom proprietary "URI dialling", so I guess you must have either tried it from a stand-alone Polycom or a LifeSize system when it worked, however, it will not work when registered to a VCS-C as it is not H.323 Annex O compliant.
Alias@domain is the correct standard based Annex O format, but Alias@IP_address is also acceptable.
You can allow Polycom systems to call you using the proprietary format by implementing a pre-search transform, but this will only work for incoming calls.
I.e.using presearch transform:
Pattern string: (.*)##(.*)
Replace: \2@mydomain
will transform 1.1.1.1##11111 to 11111@mydomain
You can change mydomain to whatever fits your requirements.
As Martin pointed out; if you're NAT'ing the VCS-E, then you need the dual-nic option installed.
/jens
