09-19-2012 08:30 AM - edited 03-17-2019 11:49 PM
Hello guys,
Anyone ever tried to use the Prequal Assistant?
I'm having trouble getting past the Calendar Server config. In my scenario, I must integrate with a MS Exchange 2010 cluster which uses one virtual IP / FQDN to handle all requests. When I try to run the Calendar tests, I get:
ERROR - Failed to test connection to Calendar server: Unable to establish connection with Microsoft Exchange server because HTTP/1.1 302 Redirect
As far as the mail admin is telling me, to connect directly to one Exchange server is not an option.
Any ideas will be greatly appreciated
Solved! Go to Solution.
09-20-2012 01:04 PM
Hi ionutionescu,
Can you confirm that you're running the EWS test from the prequal tool and not the WebDAV test (System -> Select Calendar Server -> Microsoft Exchange EWS)? I believe we see this error when the wrong thing is selected.
If not:
Is a firewall/proxy between the computer you're running the PQT and Exchange?
Is it possible to test it with one CAS server to see if the results are any different, or is that completely impossible?
- Tyler
09-20-2012 01:04 PM
Hi ionutionescu,
If not:
- Tyler
09-21-2012 07:01 AM
Thank you, Tyler... I did not see that menu for the very life of me :|
