Expressway X14.2 Licensing
ln33147
Level 4
Level 4
We will be installing new EXP C & E version X14.2 for MRA use only. Checking the Smart Account and the BoQ, couldn't find any licenses related to the Expressways. In this case, can the EXP-C and EXP-E server register to the smart account?
Thanks & Regards,
Yes they can. Expressway in MRA mode does not require any specific license. It’s a unlicensed feature since awhile back.
Response Signature
6 Replies 6
Response Signature
Apart from licensing, are there any specific reason for why you’re setting up the new system on x14.2 when there is x15.0.3?
Response Signature
ln33147
Level 4
Level 4
Hello Roger,
Thank you for taking the time to respond.
I do know that MRA doesn't require a license; my question is if there is any server registration license for EXP-C & E.
Regarding the version, we will install the latest one.
No there are no server registration license for EXP-C & E, it will just show up as a Product Instance in the Smart Licensing portal once you register it.
This is an example of our MRA cluster at one of our data centers.
Response Signature
ln33147
Level 4
Level 4
Noted. Thanks so much Roger.
Appreciate if you would mark your post as solved if you see that this is applicable.
Response Signature
