08-28-2012 10:42 PM - edited 03-17-2019 11:41 PM
Hi, i have created several permanent conferences on MCU.
Sometimes permanent conference appear as finished. Operators swear they did not finish them manualy.
Also, then i put conference back, by editing its properties and checking "permanent" checkbox, it suddenly begins to call all ex-participants into conference although there were NO preconfigured participants.
This caused much havoc and disturbance, calling BIG BOSSES and so on.
Any suggestions?
MCU software:
| version | 4.3(2.30) |
| variant | 6.18(2.30) |
Solved! Go to Solution.
08-29-2012 03:02 AM
Yes, this is what I would expect to happen. When adding participants to a permanent conference using TMS, they are added as pre-configured participants, but TMS never removes them. See bug CSCtr35038 for more information.
08-28-2012 10:49 PM
Hi utair
Is TMS in the picture of this?
/Magnus
08-28-2012 10:55 PM
Yes, it is.
You think it's TMS acting bad?
Which options to look at?
08-29-2012 02:08 AM
I would advise enabling the audit log under logs->Audit log on the MCU. That way if some configuration change is made to end a permanent conference, it will be recorded in this log which user made the change and wether they made the change via the web interface API (i.e. TMS) etc. This should enable you to track down why the conferences are being ended unexpectedly.
Regarding the preconfigured participants, it is possible that if preconfigured participants are added via the API (probably TMS unless you have other API applications) and are not removed before the conference is ended then they will persist in the configuration and not be visable via the web interface.
08-29-2012 02:50 AM
Thanks, will check that.
But, even if that conference were deleted using TMS without first removing participants, some certain participants were 100% not in conference at the moment, and still, they were called upon conference return to permanent state.
08-29-2012 02:57 AM
Just tested:
- created permanent conference using MCU interface
- added two participants using TMS
- endpoints were called into conference
- answered on both endpoints
- hung up on one endpoint
- kicked another one out of conference using TMS
- delete that conference using TMS
- restored that "completed" conference back to permanent using MCU
- both endpoints were called back into conference automatically! very funny.
08-29-2012 03:02 AM
08-29-2012 03:17 AM
Even more, they remain after reboot and called after.
08-29-2012 03:18 AM
Any ETA on fix?
08-29-2012 03:53 AM
Unfortunately we do not have any information as to when this may be fixed at this time.
