05-10-2016 08:55 AM - edited 03-18-2019 05:54 AM
I have an MX800 device that is on Software version: ce 8.1.0 Final b8c0ca3 2016-04-05
It is registered in call manager and for some reason the Meeting button is not available. Is there some way I can add the meeting button back on the Touch 10 panel?
John
05-10-2016 09:29 AM
Was the MX700 ever managed by TMS at some point? Usually the meeting button appears for directly managed endpoints added into TMS.
05-10-2016 10:02 AM
This is an MX800 and I registered it first in Call Manager and then added it in TMS.
05-12-2016 06:02 PM
Have you scheduled a meeting for this device yet?
Normally the meeting icon doesn't appear on Telepresence endpoints until a meeting is set up in the TMS system.
07-11-2016 11:41 AM
I just ran into this issue with my two latest installs. [MX300 G2 equipped with TC7.3.5]. Both these units are registered with TMS and I have scheduled a meeting via TMS per the recommendations on this thread. The meeting button/icon still does not appear!
05-12-2016 10:24 PM
Have you checked that it's correctly added to TMS, and that TMS can access it properly, as the meetings button is something that will be activated once TMS can see it can schedule a conference on it.
07-11-2016 11:40 AM
07-15-2016 04:54 PM
If you connect via SSH to the codec, and use the API command: xCommand Booking List, does anything appear? If nothing appears, then either TMS isn't pushing the bookings to the endpoint, or the endpoint isn't receiving them.
In the endpoint logs (eventlog/all.log), you should see something similar to the below:
CuilApp User root(0) about to execute command '/Bookings/List' from .
If there are bookings present on the endpoint, you could try to restart it to see if the meeting icon appears.
