01-23-2014 04:50 AM - edited 03-18-2019 02:28 AM
Hi everybody,
I have a issue when I try to load the MIDLET in the IP Phone 7975, I rececive a error: "Error, contact administrator".
I have configured two MIDLETS services, one for Publisher and another for Subsriber.
The version of the devices are the following:
Cisco CUCM--> 9.1.2
CTS-500 37"--> 1.8.5(4)_P1
IP Phone 7975-->SIP75.9-2-1S
MIDLETS Version is--> TSPM-1.8.2-P1-1S
The IP Phone Service is configured fine because I copy the url of this IP Phone Service and no error appears in the browser.
The CTS 500 in device information get the IP, Mac Address and version of the IP Phone; but in Status Detail shows the following:
Connection: error; Software: Unable to retrieve software version
In URL of the IP Phone I have got the next logs:
|== Syslogd TNP== Thu Jan 23 13:34:35 2014
6422: NOT 13:34:35.356640 JVM: Startup Module Loader|cip.midp.midletsuite.InstallerModule:? - Downloading Jad...MIDLETS SUB
6423: ERR 13:34:35.405343 JVM: Startup Module Loader|cip.midp.midletsuite.ah:? - The Url http://X.X.X.X:6970/TSPM-1.8.2-P1-1S.jad is availabe, use this IP address.
6424: ERR 13:34:36.199305 JVM: 13:34:36|Install Exception: Missing suite name:
at cip.midp.midletsuite.ah.h()V(Unknown Source)
at cip.midp.midletsuite.ah.a(Lcip/midp/midletsuite/u;Lcip/cfg/XmlServiceObject;)V(Unknown Source)
at cip.midp.midletsuite.ah.a(Lcip/srvc/z;Ljava/lang/String;ZZLcip/midp/midletsuite/p;Lcip/cfg/XmlServiceObject;)V(Unknown Source)
at cip.midp.midletsuite.ah.a(Lcip/srvc/z;ZZLcip/midp/midletsuite/p;Lcip/cfg/XmlServiceObject;)V(Unknown Source)
at cip.midp.midletsuite.InstallerModule.a(Lcip/cfg/XmlServiceObject;)V(Unknown Source)
at cip.midp.midletsuite.z.a(Lcip/midp/midletsuite/b;Lcip/sys/x;)V(Unknown Source)
at cip.midp.midletsuite.z.sinkMessage(Lcip/sys/x;)V(Unknown Source)
at cip.sys.n.sinkMessage(Lcip/sys/x;)V(Unknown Source)
at cip.sys.aa.a(Lcip/sys/ad;)Ljava/lang/Throwable;(Unknown Source)
at cip.sys.aa.e()V(Unknown Source)
at cip.sys.l.run()V(Unknown Source)
at java.lang.Thread.startup(Z)V(Unknown Source)
6425: NOT 13:34:36.203955 JVM: Startup Module Loader|cip.midp.midletsuite.InstallerModule:? - Midlet Install Canceled/Error...MIDLETS SUB
6426: NOT 13:34:37.807561 JVM: Startup Module Loader|cip.srvc.Services:? - Service url used http://X.X.X.X:8080/ccmcip/getservicesmenu.jsp
6427: NOT 13:34:37.809126 JVM: Startup Module Loader|cip.srvc.Services:? - Service url used http:/X.X.X.X:8080/ccmcip/getservicesmenu.jsp
6428: WRN 13:34:39.372046 JVM: Startup Module Loader|class cip.srvc.XsiMIDletSuiteResponse:(updateStatus( - 0)not handled)
6429: ERR 13:34:39.393814 JVM: Startup Module Loader|cip.midp.midletsuite.ah:? - The Url http://X.X.X.X:6970/TSPM-1.8.2-P1-1S.jad is availabe, use this IP address.
6430: ERR 13:34:40.212716 JVM: 13:34:40|Install Exception: Missing suite name:
at cip.midp.midletsuite.InstallerModule.a(Lcip/srvc/bj;Lcip/midp/midletsuite/p;)V(Unknown Source)
6431: ERR 13:34:46.631911 JVM: Calling enable listening for incoming http connections
6432: ERR 13:34:46.692003 JVM: Calling enable listening for incoming http connections
I change the IP address of CUCMs fot X.X.X.X.
I have followed the documentation to register all fine and to erase the IP Phone to factory defaults to removed the old midlet but I don't get that is working fine.
If I do call from other Video Endpoints the CTS is working fine and the shared line between CTS and IP Phone too.
Can anybody help me?
Thanks in advance.
Best regards.
Solved! Go to Solution.
01-24-2014 07:02 AM
You will need to change the Service Name and the ASCII service name to the following:
TSPM-1.8.2-P1-1S
And then Reset the phone from CUCM. Let me know if that clears it up.
-Jonathan
01-23-2014 05:12 AM
Here are some images.
Regards.
01-23-2014 07:52 PM
Hi, could you post a screen shot of the midlet configuration page from CUCM, I'd like to verify there are no issues with the configuration.
- Jonathan
01-24-2014 03:32 AM
Hi Jonathan,
Here are the screenshots.
Regards.
01-24-2014 02:03 AM
Please note that the TFTP database does not replicate over a cluster, so make sure the midlet file is available on both servers ( if you use them both for TFTP and for midlet services )
If you have uploaded both files on the publisher and pointed the second midlet service to the subscriber then the service will not load on the IP Phone.
//Marius
01-24-2014 03:33 AM
Hi Marius,
Yes, the files are iuploaded in both Server, Publisher and Subscriber.
Thanks.
01-24-2014 07:02 AM
TSPM-1.8.2-P1-1S
-Jonathan
01-28-2014 03:41 AM
Hi Jonathan,
I have modified the Service and ASCII name and now the IP Phone is working fine.
Thank you for the help.
Regards.
