Non-Immersive endpoints can we put feedback ratings using Macro
Anurag Srivastava1
Hello Experts,
Can we put some pop-up for feedback rating on non-immersive endpoints when every calls ends using macro framework?
If yes, how this will work and where this feedback will be stored?
Does anyone has applied this and have any sample script?
Any suggestions will be really helpful.
Thanks.
Please rate if it is helpful and mark as accepted solution if applicable....
Mike_Brezicky
Have you checked out the sample macro's from DevNet?
The customer Satisfaction Survey - https://github.com/CiscoDevNet/roomdevices-macros-samples/tree/master/Customer%20Satisfaction would be one to check out. I have tried it and have it set so that it will post the feedback to a Teams Room for me to review. I think you can have it send the feedback to an email recipient, but have not tried that yet.
Hi @mike
Thanks for the information. i will try this :-)
