Precision HD1080p
david.sharp
i wonder if any one can assist with a problem that we have.
we have a couple of older precision HD1080p camera's which we are currently unable to retrieve any image from on the HDMI.
The camera details are as follows.
model, Precision HD1080p 12x
revision: 3
software version: S01718-4.0FINAL [ID:40076] 2012-05-16
the problem is that we have recently upgraded the firmware on our C60 codec which has two of these camera's connected.
originally the problem was that we could not see any image from the main cam, but the auxiliary camera worked fine.
the codec still sees the camera's which is why i am able to confirm the software revision, however the primary camera does not transmit any video over HDMI.
we swapped the camera's round, so the primary became the auxiliary and the auxiliary camera became the primary, the codec noticed the camera was on an older firmware version and performed a firmware update on the camera to the version as detailed above, we now have two cameras that will not output on HDMI to the codec.
we have tried in vein to push a firmware upgrade to the cameras for the latest version of firmware as noted for the C20 systems ( i suspect the firmware is the same for these camera's) we have upgraded the codec to TC5.1.3 which is stated to contain the latest firmware for these camera's but the codec is not upgrading the cameras. I cannot find any command to manually upgrade the camera from the codec (a force camera upgrade command) and when we attempt to connect to the camera over IP it doesn't appear to pickup an IP address, what also concerns me is that in the camera status the camera appears to not have a MAC address (maybe this is why it will not pickup an IP address).
This camera has no USB port and I cannot connect to the camera using a null modem cable and a camera cable (as I would when performing a software recovery on a C20 camera) via RS232 I have attempted this using the same details I would with a C20 camera but I receive no response what so ever from the camera (yes it is powered on using a 12v 4amp power supply (the standard codec power supply as used hundreds of times before))
so I am now absolutely stumped as to how I can fix the problem with the camera, I expect if I can get the camera onto the latest firmware revision that all would be well, as I have connected a C20 camera, the 4x with the USB socket into the auxilary camera position (don't want to connect it as primary camera wouldn't want another codec upgrade to take place) and I receive video and control no problem.
any pointers on how I could recover this camera, preferable without having to go to RMA, due to an administrative mixup I don't think the system is covered under a support agreement.
If you need any more information please do give me a shout I shall gladly provide what ever I can find.
as always and and all assistance greatly appreciated.
Cheers
Dave
Think with Portals
25 Replies 25
mubakhta
Level 4
Level 4
Hi David,
The information provided by you for the issue is very detailed and helpful. You have basically performed all the possible steps in order to recover the camera.
There are a few ways which we can try to force the camra to upgrade however, we would recommend that you open a TAC case as those methods are not advised to be performed via emails. We would appreciate if you can open a TAC case and come on a remote session, we can try to help you out. You can request to speak to me and I will personally make sure it is handled in a timely manner.
Mubashshir Akhtar
Thanks Mubashshir Akhtar
Danny De Ridder
the procedures for 4X camera are not applicable to 12X. Different cameras. The codec does seem to recognise your camera via the VISCA protocol over the serial cable, so you could try to start an upgrade using the codec. To do this, go into tsh by logigng into the codec using admin password.
[tandberg:~] $ tsh
Welcome to
Cisco Codec Release TC5.1.0.280662
SW Release Date: 2012-02-14
OK
sys-f
OK
com camvisca 0 swload /mnt/base/active/rover.pkg
OK
CamVisca: Load SW image /mnt/base/active/rover.pkg to camera 1 from codec
You can check the packages on your system when using ssh and logging as root :
[dderidde-sx20:~] $ ls -lrt /mnt/base/active/*.pkg
-rw-r--r-- 1 root root 6764568 Aug 29 09:23 /mnt/base/active/a7camera.pkg
-rw-r--r-- 1 root root 6025232 Aug 29 09:23 /mnt/base/active/nandi.pkg
-rw-r--r-- 1 root root 4375216 Aug 29 09:23 /mnt/base/active/sangam.pkg
-rw-r--r-- 1 root root 4347385 Aug 29 09:23 /mnt/base/active/rover.pkg
[dderidde-sx20:~] $
rover.pkg is the one used for 12X camera.
Hi Danny
Thank you very much for confirming these details (much appreciated, information like this is gold dust), I have used this command and forced the codec to perform a firmware update on the camera, which the codec appeared to be doing, is there a method I can tell remotely once the camera has been upgraded from the original SSH session?
I have telnet into the system again and checked the firmware version of the camera which is the same as the above, is rover the latest firmware version available as detailed above, or should I expect to see a different firmware version on the camera?
I confirmed the rover package was in the active location as detailed by the UNC path above by using winSCP and browsing to that location, so I am sure the file structure is ok, I think we maybe looking at a bug with the firmware on the camera.
I understand that the codec should automatically reboot the camera, but without giving the unit a physical reboot I cannot be certain the unit has restarted.
the room is in use at the moment, is there anything else you could suggest until i get round to giving the camera a physical kick (maybe not so metaphorically).
Cheers
Dave
Think with Portals
if you have root access to the unit, you can check the console log. Like this :
cat /var/log/console
You should see message related to camera upgrade.
       Camera SW upload started
WARNING:
Camera is being upgraded.
Do NOT switch off the system!
Upgrade completed successfully.
Camera will now be restarted.
Hi Danny
Once again thanks for the info, very useful stuff, I had to dig the log file out of a different directly, never thought of checking it.
the log does state exactly as you have suggested in your reply, that the camera firmware upgrade has completed successfully.
when i do the xstatus camera 1 i see the following line
SoftwareID: "S01718-4.0FINAL [ID:40076] 2012-05-16"
which looks like the latest firmware version, is there a different version we can choose, a newer version or could we potentially downgrade the camera to a version a couple of revisions back, as the secondary camera was working ok until we swapped it and the codec upgraded it.
Also is there command we can add to prevent the codec from automatically performing the firmware update of the camera.
I have also given the camera a hard reboot by disconnecting it from the codec.
Cheers
Dave
Think with Portals
the camera pkg is bundled with the codec software. If you connect a camera with a lower revision to a codec which has a higher revision camera software, the codec will upgrade it.
If you know the codec version where the camera still worked, you could copy the package from that codec and copy it over to your codec which has the faulty camera and force this package to the camera using the commands explained above.
You can use scp to copy over files.
[dderidde-sx20:/mnt/base/active] $ scp dderidde@10.48.160.30:/home/dderidde/bogus.pkg .
dderidde@10.48.160.30's password:
bogus.pkg        100%    0     0.0KB/s   00:00
dderidde is my username on a system with IP address 10.48.160.30 which has a file named /home/dderidde/bogus.pkg copied over to my current directory on the codec.
I do not know of a way to prevent a codec from upgrading the camera.
There's a ddts open for 12X cameras and no video. CSCtx58429 entitled "CTS-PHD-1080P12X camera no video issue".
I would recommend opening a Service Request so TAC can help to use the steps outlined in CSCtx58429 to gather more info or RMA the camera and tag it for Failure Analysis for engineering to look at.
Hi David,
You may follow this on your own analysis and risk.
Only way I can think of is to remove the rover.pkg(This is the name of 1080p 12x camera) from the Codec S/W package by logging in through WINSCP.
Also you can force upgrade the 12x camera on LAN. Do it this way. Camera should be able to get IP from DHCP server on network if that is there and DHCP of the camera is turned on. However as you said it did not work try following way. Also camera needs reboot after enabling the same.
Please understand that if you flip-flop the configuation of DHCP of camera, this will reboot camera.
Connect Camera to the (RJ45 LAN port) to your laptop directly and assign static IP say 192.168.1.2 on the NIC of laptop.
Then get TFTPD32 to assign IP automatically of the same range through DHCP of TFTPD32.
Then you can start the upgrade. Through TFTPD323 you will come to know which IP is assigned to camera or you will need to console into codec and get the xsta camera display that information of IP being assigned to camera.
You can refer to the following link for upgrade on LAN.
http://developer.cisco.com/documents/5366396/5ae62b7d-fa73-45e2-bdea-ead7ca4f73f3
Bhaskar
Hi Danny (and others)
Thank you very much for providing the information you have, I have indeed learnt a lot from this experience, and am taking very valuable information away with me.
we have spent another morning looking at this issue (it has indeed proven rather difficult to pinpoint where the issue is) and i think we have finally found what the problem is.
I think we have a compatibility issue between the latest firmware on the camera's and a couple of slightly older firmware versions also and an HDMI extender over cat5 that we use.
Firstly the system as setup has been running perfectly 100% A, OK for 2 years (hense the original suspision of the firmware).
the HDMI extender we use is a Kramer TP551N (like I say above, this has worked flawlessly for 2 years or more now).
from our testing we found the following (using the command and information provided above by yourselves).
Firstly and I guess most importantly for Cisco is if i use a 4x camera running firmware version 20008 and above the system works, what I did originally to provide a slight work around was replace the auxiliary 12x camera with a 4x from a C20 and this worked perfectly fine, but when we replaced the 4x with the original 12x camera we would get no video
(the control hasn't been a problem all along).
We recently performed an RMA on another system that was to sit in our maintenance stock for a period of time, which came in late yesterday evening, so this proved a very useful testing tool this morning, we found that we did not get any video from this camera also, but as this was an RMA we could not be certain what firmware version the camera was on, so we attached this camera to a C20 codec which long and behold upgraded the firmware on the camera to
40075 which worked perfectly well with the C20 but again wouldn't work with the C60, I copied the rover camera package from the C20 and replaced the rover camera package on the C60 so that if the system was to perform another upgrade to a camera it would at least be to a controlled firmware version that we know the camera certainly does work ok on. this however proved fruitless also, we still had two camera's with no video to the codec.
Again if we attached a 4x camera we received video, so to prove the camera's could communicate with the codec we dug out some power supplies and different cables and when connecting the camera's directly to the codec we found that we received video no problem at all on both camera's which leads me to believe we had a problem with the HDMI extenders (I'm sure we didn't get video the last time we connected the camera directly to the codec, maybe was was being impatient).
At this point I went on a hunt for either an EDID minder or another box where the manufacturer specifically states that the EDID is catered for, and found an Extron HDMI extender that specifically forwards EDID exchanges on, we installed this Extron solution and the camera's are working without issue again.
So in brief.
it would appear there is a problem with the latest camera firmware and the Kramer HDMI extender. but on the flip side what ever has been done to improve the 4x camera would appear to have fixed this issue also as we didn't experience the problem with a 4x camera at all.
Again thank you all for your information and assistance.
i hope this feedback proves useful to the R+D team if you need any more info please do give me a shout.
on another note, the camera hardware in this instance for the 12x camera is rather old, they state rev3 on the underside (maybe this is part of the problem).
Cheers
Dave
Think with Portals
the only thing I can think of to check would be the status of the video on the C60 codec. I only have a C40 in the lab, but the output of the commands should be the same. E.g. this :
xstatus Video Input hdmi 1
*s Video Input HDMI 1 Connected: True
*s Video Input HDMI 1 SignalState: OK
** end
xstatus Video Input source 1
*s Video Input Source 1 Resolution Height: 720
*s Video Input Source 1 Resolution Width: 1280
*s Video Input Source 1 Resolution RefreshRate: 60
*s Video Input Source 1 Resolution FormatType: Digital
*s Video Input Source 1 Resolution FormatStatus: Ok
** end
OK
What would the non-working camera show?
Also, we can check some more details on the Video Processing Engine [VPE] too by logging into it. HDM1 on C60 is controlled by VPE0. We can connect to the VPE from tsh :
sys-con vpe0
****** Welcome to SYSTEM_VPE0 ******
Use 'quit' to end connection
OK
Connected
vpe-info all
FPGA 0, max 6/4 loc/dsp0 windows
32 phases, selected phase/quality 30/832
        phases  0- 7: 832 416 416   0   0   0   0   0
        phases  8-15:   0   0   0   0   0   0   0   0
        phases 16-23:   0   0   0   0   0   0   0   0
        phases 24-31:   0   0 277 800 832 832 832 832
valid local inputs for FPGA 0:
        16 (Multiplexed video link) (1280x720)
        64 (Decoded video stream)
        65 (Decoded video stream)
        128 (HDMI) (1280x720@60)
valid remote inputs for FPGA 0:
        17 (Multiplexed video link)
        20 (Multiplexed video link)
        66 (Decoded video stream)
        67 (Decoded video stream)
        68 (Decoded video stream) (1920x1080)
        81 (Menu stream) (1920x1080)
valid outputs for FPGA 0:
        0 (HDMI) (1920x1080@60)
        64 (DSP0) (0x0)
        65 (DSP1) (0x0)
inactive window configuration for HDMI output on FPGA 0:
        0: 10000x10000@0x0 source 81 fitmode 1 border 0 active 1
        1: 10000x10000@0x0 source 68 fitmode 2 border 0 active 1
        5: 2432x2432@7084x7154 source 16 fitmode 0 border 1 active 1
inactive window configuration for DSP0 output on FPGA 0:
inactive window configuration for DSP1 output on FPGA 0:
mux 0: vp0=link  0, source  1
mux 1: vp0=link 15, source  1
mux 2: vp0=link 15, source  0
mux 3: vp0=link 15, source  0
mux 4: vp0=link 15, source  0
mux 5: vp0=link  0, source  1
driver: vpe0 (America rev B/D), uptime: 61d 3h 4m 53s, no GHz ARM
videorx: source HDMI-1 (128) on primary input, enabled, not encrypted
videorx: local input detection: 1280x720@60.0
videotx: display on HDMI-1: 1920x1080@60 (powersaving off)
         frame 2200x1125, front porch 88/4, sync width 44/5, polarity +/+, hdmi, digital
         pix_freq 148.500000 Mhz
videotx: dsp0: 0x0@0
videotx: dsp1: 0x0@0
videodetector: lvds 0, source 16: 1280x720p
videodetector: lvds 16, source 81: 1920x1080p
ad9388a: input HDMI, drive strength 2
ad9388a: HDMI signal, no DVI-D signal, unknown analog signal
ad9388a: digital has lock, TMDS pll has lock, deglitch filter is on
ad9388a: CSC mode: auto. Detected color space: RGB full. Coefficient preset selected: 5
ad9388a: detected DVI-D video format 1280x720p
ad9388a: frame size 1650x750, front porch h=111 v=5, sync h=40 v=5, pix_freq=74.24 Mhz
ad9388a: audio pll: 0, enabled: 1, locked: 0, coast: 7f, sample detect: 00 00
ad9388a: position correction: hor 0/0, ver 0/0, de 0/0
ad9389b: detected hotplug, detected Rx Sense, found EDID, HDMI output enabled
ad9389b: no encryption
ad9389b: state: idle, error: no error, detect count: 20, msk/irq: c4/20
ad9389b: RGB quantization: full range
ad9389b: manual gear 4
ad9389b: CTS automatic mode: N 6144, CTS 148501
ad9389b: VIC: detected 16, sent 16
idt5v9885b: 148500 kHz M=16 P=8 D=1 IpRz=0x33 CpCz=0x74
IRQ              Total
vpe_timer        : 5281522
api_req          : 205
system_status    : 64
core_status      : 10622363
hdmi_in          : 5
hdmi_out         : 59
detect_input     : 0
pll_lock_lost    : 0
ddrcache0        : 3
ddrcache1        : 2
detect_output    : 10620407
local_scaler     : 0
dsp0_scaler      : 0
dsp1_scaler      : 0
vsink_local      : 265
vsink_dsp0       : 1
vsink_dsp1       : 0
vsource_local    : 140
vsource_dsp0     : 1545
vsource_dsp1     : 0
local_composer   : missing: 3 framereq: 0
dsp0_composer    : missing: 0 framereq: 0
dsp1_composer    : missing: 0 framereq: 0
local_crop       : 0
dsp0_crop        : 0
dsp1_crop        : 0
dsp0_oversampler : 0
dsp1_oversampler : 0
cec_hdmi_tx      : 1080
cec_hdmi_rx      : 0
OK
You can also print the edid :
print-edid 0
Main EDID:
Manufacturer: CIS(3379)
ProductCode: 1174
SerialNumber: 0
WeekOfManufacture: 46
YearOfManufacture: 2010
EDIDVersionNumber: 1
EDIDRevisionNumber: 3
SignalLevel: Digital
SignalLevelStandard:
Setup:
SupportsSeparateSyncs:
SupportsCompositeSync:
SupportsSyncOnGreen:
Could that reveal something when the camera is not working???
Hi Danny
Once again excellent information provided, i can confirm that there is no video input on source 2
xstatus video input source 2
*s Video Input Source 2 Resolution Height: 0
*s Video Input Source 2 Resolution Width: 0
*s Video Input Source 2 Resolution RefreshRate: 0
*s Video Input Source 2 Resolution FormatType: Unknown
*s Video Input Source 2 Resolution FormatStatus: Error
** end
although the HDMI is connected ok, the format is shown as above.
note entirely certain what i am looking for in the VPE info, its all a bit confusing, does anything stand out to you?
sys-con vpe0
OK
Connected
vpe-info all
32 phases, selected phase/quality 1/832
        phases  0- 7: 832 416 416 832 791  32   0   0
        phases 24-31:   0   0   0   0   0 612 832 832
        16 (Multiplexed video link) (1920x1080)
        128 (HDMI) (1920x1080@60)
        81 (Menu stream) (1024x768)
        0 (HDMI) (1024x768@60)
        64 (DSP0) (0x0)
        65 (DSP1) (0x0)
        1: 10000x10000@0x0 source 16 fitmode 0 border 0 active 1
mux 1: vp0=link  0, source  1
mux 5: vp0=link 15, source  0
driver: vpe0 (Casper rev F/C), uptime: 5d 1h 56m 51s, no GHz ARM
videorx: local input detection: 1920x1080@60.0
videotx: display on HDMI-1: 1024x768@60 (powersaving on)
         frame 1344x806, front porch 24/3, sync width 136/6, polarity -/-, hdmi, digital
         pix_freq 65.0 Mhz
videodetector: lvds 0, source 16: 1920x1080p
videodetector: lvds 16, source 81: 1024x768p
ad9388a: input HDMI, drive strength 3
ad9388a: detected HDMI video format 1920x1080p
ad9388a: frame size 2200x1125, front porch h=89 v=4, sync h=44 v=5, pix_freq=148.48 Mhz
ad9388a: audio pll: 0, enabled: 1, locked: 1, coast: 7f, sample detect: 08 01
ad9389b: detected hotplug, detected Rx Sense, found EDID, HDMI output disabled
ad9389b: state: idle, error: no error, detect count: 1, msk/irq: c4/20
ad9389b: manual gear 1
ad9389b: CTS automatic mode: N 6144, CTS 64999
ad9389b: VIC: detected 0, sent 0
idt5v9885b: 65000 kHz M=520 P=18 D=33 IpRz=0x4d CpCz=0xa5
IRQ              Total
vpe_timer        : 439011
api_req          : 10
system_status    : 1703
core_status      : 932856
hdmi_in          : 1701
hdmi_out         : 2
detect_input     : 0
pll_lock_lost    : 0
ddrcache0        : 3
ddrcache1        : 0
detect_output    : 920957
local_scaler     : 56
dsp0_scaler      : 0
dsp1_scaler      : 0
vsink_local      : 4
vsink_dsp0       : 0
vsink_dsp1       : 0
vsource_local    : 10013
vsource_dsp0     : 1830
vsource_dsp1     : 0
local_composer   : missing: 1 framereq: 0
local_crop       : 0
dsp0_crop        : 0
dsp1_crop        : 0
cec_hdmi_tx      : 0
cec_hdmi_rx      : 0
OK
the EDID info looks to be ok to me, i can't see anything obviously wrong with it
OK
print-edid 0
Main EDID:
Manufacturer: IVM(9933)
ProductCode: 22024
SerialNumber: 16843009
WeekOfManufacture: 0
YearOfManufacture: 2009
Setup:
SerrationRequired:
DFPSupported: Yes
DisplaySizeKnown: No
Max Horizontal Image Size = 55 cm
Max Vertical Image Size = 34 cm
Nearest Known Aspect Ratio = 16:10
DisplayTransferCharacteristic: (120 + 100.0)/100.0
SupportsDPMSStandby: No
SupportsDPMSSuspend: No
SupportsDPMSActiveOff: Yes
SupportsDefaultColorSpace_sRGB: No
SupportsPreferredTimingMode: Yes
SupportsDefaultGTF: No
ColorCharacreristics: R (646,335), G (283,601), B (149,072), W (313,329)
Established Timings:
    800x600@60Hz
    640x480@75Hz
    640x480@72Hz
    640x480@67Hz
    640x480@60Hz
    720x400@70Hz
    1280x1024@75Hz
    1024x768@75Hz
    1024x768@70Hz
    1024x768@60Hz
    832x624@75Hz
    800x600@75Hz
    800x600@72Hz
Standard Timing Identification:
    Refresh rate: 75Hz
    Horizontal active pixels: 1152
    Image aspect ratio: 4:3
    Refresh rate: 60Hz
    Horizontal active pixels: 1280
    Image aspect ratio: 5:4
    Refresh rate: 75Hz
    Refresh rate: 60Hz
    Horizontal active pixels: 1440
    Image aspect ratio: 16:10
    Refresh rate: 75Hz
    Refresh rate: 60Hz
    Horizontal active pixels: 1600
    Refresh rate: 60Hz
    Horizontal active pixels: 1680
Monitor Descriptor Data (Type = Monitor Range Limits):
    Min vertical rate: 55 Hz
    Max vertical rate: 76 Hz
    Min horizontal rate: 29 kHz
    Max horizontal rate: 81 kHz
    Max pix clk: 170 MHz
    No secondary timing formula supported
Monitor Descriptor Data (Type = Monitor Name):
    PLE2607WS
Detailed Timing Description:
    PixelClockDiv10000 : 15400
    Horizontal Active : 1920
    Horizontal Blanking : 160
    Vertical Active : 1200
    Vertical Blanking : 35
    Horizontal Sync Offset : 48
    Horizontal SyncPulse Width : 32
    Vertical Sync Offset : 3
    Vertical SyncPulse Width : 6
    Horizontal Image Size : 550 mm
    Vertical Image Size : 344 mm
    Horizontal Border : 0
    Vertical Border : 0
    Flags : 0x0000001a
    - Non-Interlaced
    - Normal display, no stereo
    PixelClockDiv10000 : 13850
    Vertical Active : 1080
    Vertical Blanking : 31
    Horizontal Sync Offset : 80
    Vertical Sync Offset : 8
    Vertical SyncPulse Width : 5
    Vertical Border : 0
    Flags : 0x0000001a
    - Non-Interlaced
Extension flag (#extension-blocks) : 1
CEA-861-D EDID:
Revision Number : 3
Number of native DTDs: 1
Underscan IT by default: Yes
Basic audio support: Yes
YCbCr 4:4:4 support: Yes
YCbCr 4:2:2 support: Yes
Audio block
    Format: Linear PCM
    Max channels: 2
    Sampling frequency: 48kHz 44.1kHz 32kHz
    Sample size: 16bit
Video block
    1920x1080@60i 16:9 Native
    1920x1080@60p 16:9
    1280x720@60p 16:9
    720x480@60p 16:9
    720x480@60i 4:3
    720x576@50p 16:9
    720x576@50i 16:9
    720x576@50p 4:3
    640x480@60p 4:3
    1920x1080@50i 16:9
    1920x1080@50p 16:9
HDMI Vendor
    IEEE Reg Id: 0x000c03
    Source Physical Address (A.B.C.D) = (1.0.0.0)
    Supports AI: No
    Supports 30 bits/pixel (10 bits/color): No
    Supports 36 bits/pixel (12 bits/color): No
    Supports 48 bits/pixel (16 bits/color): No
    Supports YCbCr 4:4:4 in Deep Color modes: No
    Supports DVI dual-link operation: No
Speaker Allocation block
    Speaker placement: FL/FR
    PixelClockDiv10000 : 7425
    Horizontal Active : 1280
    Horizontal Blanking : 370
    Vertical Active : 720
    Vertical Blanking : 30
    Horizontal Sync Offset : 110
    Horizontal SyncPulse Width : 40
    Vertical Sync Offset : 5
    Vertical Border : 0
    Flags : 0x0000001e
    - Non-Interlaced
    Horizontal Blanking : 280
    Vertical Active : 540
    Vertical Blanking : 22
    Horizontal Sync Offset : 88
    Horizontal SyncPulse Width : 44
    Vertical Sync Offset : 2
    Vertical Border : 0
    Flags : 0x0000009e
    - Interlaced
    PixelClockDiv10000 : 2700
    Horizontal Active : 720
    Horizontal Blanking : 138
    Vertical Active : 480
    Vertical Blanking : 45
    Horizontal Sync Offset : 16
    Horizontal SyncPulse Width : 62
    Vertical Sync Offset : 9
    Vertical Border : 0
    Flags : 0x00000018
    - Non-Interlaced
    Horizontal Active : 1440
    Horizontal Blanking : 276
    Vertical Active : 240
    Horizontal Sync Offset : 38
    Horizontal SyncPulse Width : 124
    Vertical Sync Offset : 4
    Vertical SyncPulse Width : 3
    Vertical Border : 0
    Flags : 0x00000098
    - Interlaced
OK
i think the xstatus input source has clarified it for me, although the signal is there, especially as i can see noise when power cycling the camera, the actual video properties are not synchronising through, and when i check on the Kramer box i can see the lights doing the random slow blink, which suggests to me that the Kramer isn't sychronising the resolution correctly, only solution i can imagine at the moment is to replace the Kramer box.
Cheers
Dave
Think with Portals
Think with Portals
since your troubled video input is 2, we need to check the edid commands on VPE1 instead of VPE0. VPE1 controls the input for input 2. Can we connect to vpe1 and repeat the commands?
print-edid 0
vpe-info all
And maybe
eventlog
Ah ha here we go, problems
sys-con vpe1
****** Welcome to SYSTEM_VPE1 ******
OK
Connected
vpe-info all
FPGA 1, max 6/4 loc/dsp0 windows
32 phases, selected phase/quality 29/832
        phases 24-31:   0 634 832 832 832 832 832 832
valid local inputs for FPGA 1:
        129 (HDMI) (0x0)
        152 (DVI-I) (0x0)
valid remote inputs for FPGA 1:
valid outputs for FPGA 1:
        8 (DVI) (1280x720@60)
        66 (DSP0) (0x0)
        67 (DSP1) (0x0)
inactive window configuration for DVI output on FPGA 1:
inactive window configuration for DSP0 output on FPGA 1:
inactive window configuration for DSP1 output on FPGA 1:
mux 0: vp0=link 15, source  0
mux 1: vp0=link  6, source  1
driver: vpe1 (Casper rev F/C), uptime: 5d 3h 6m 48s, no GHz ARM
videorx: source HDMI-2 (129) on primary input, disabled, not encrypted
videorx: local input detection: 0x0@0.0
videorx: DVI-A detected 0 hsyncs
videorx: DVI-D cable detection not present
videotx: display on DVI-2: 1280x720@60 (powersaving on)
         frame 1650x750, front porch 110/5, sync width 40/5, polarity +/+, dvi, analog
         pix_freq 74.250000 Mhz
         overscan hor=600% ver=600%
videodetector: lvds 6, source 16: 1920x1080p
ad9388a: no HDMI signal, no DVI-D signal, unknown analog signal
ad9388a: digital has no lock, TMDS pll has no lock, deglitch filter is on
ad9388a: CSC mode: auto. Detected color space: auto. Coefficient preset selected: 5
ths8200: rev 04, power on, DVI-A output disabled, 0x0
ad9389b: detected hotplug, no Rx Sense, no EDID
ad9389b: state: reading EDID, error: i2c error, detect count: 0, msk/irq: c4/00
ad9389b: automatic gear 1
idt5v9885b: 74250 kHz M=16 P=16 D=1 IpRz=0x33 CpCz=0x74
IRQ              Total
vpe_timer        : 443208
api_req          : 9
system_status    : 1186507
core_status      : 11966982
hdmi_in          : 1186506
hdmi_out         : 1
detect_input     : 0
pll_lock_lost    : 0
ddrcache0        : 2
ddrcache1        : 0
detect_output    : 929805
local_scaler     : 61
dsp0_scaler      : 0
dsp1_scaler      : 0
vsink_local      : 2
vsink_dsp0       : 0
vsink_dsp1       : 0
vsource_local    : 11035891
vsource_dsp0     : 1600
vsource_dsp1     : 0
local_crop       : 0
dsp0_crop        : 0
dsp1_crop        : 0
cec_hdmi_tx      : 0
cec_hdmi_rx      : 0
and if i attempt to print the EDID information the EDID appears to be completely missing and the system states "ad9389b: no edid read"
and below is the eventlog
eventlog
------------------------ EVENT LOG SYSTEM INFO -----------------------
Main processor: NiosII
System: VPE1
System HW ID/TS: 0/1322824636
Video board type and revision: 0x32
*** System startup, event system enabled.
Product information
Casper
Main board: F
Video board: C
Running VPE1
CPU id: 1
vpeInit: S01728A
vpeInit: VPE1, product Casper rev F/C
i2cSwReset: perform i2c startup bit-bang
vpeInit: idt5v9885b set to 74250000 Hz
lvds_calibrate: ok, slave (1), 898 ms
99 MHz
vpe_calibrate 1
dsp0 fffffffff000
dsp1 7fffffffffe
dsp0&1 7fffffff000 (best phase 27)
fsm_procSetup: Open Interprocessor comm devs.
fsm_procSetup: Initialize data structures.
fsm_procSetup: Create all FSM tasks[3].
fsm_procSetup: Check for system synchronization.
registerAndWaitForNotify: Sending id = SYSTEM_VPE1(21) (352321536)
Wait for timeout, or incoming message
calibrated crc: OK (1 attempts)
vpeInit: complete in 8467 ms
registerAndWaitForNotify: Sync message received!
fsm_procSetup: Signal tasks to run create.
fsm_procSetup: wait for create(s) to finish
fsm_procSetup: Signal tasks that operation can start.
Starting com session
irq scaler #0-1: data valid when scaler not ready
irq: local missing 02
layout_calculate_setup: #0-1: window fit error (-1) source=17 src=1280x1 dst=1128x632
layout_window_config: #0-1: calculate window config failed
OK
i'm becoming more and more confident the issue is to do with the EDID getting through to the codec.
Cheers
Think with Portals
Think with Portals
here we get :
The AD9388A high quality, single-chip graphics digitizer with an integrated 2:1 multiplexed HDMI® receiver does not detect the HDMI signal. I am unsure why the new camera firmware results into this error when usign your HDMI extender. Is signal "too hot" coming from camera? I am not well versed in HDMI standard(s). Will run this by the camera/engineering guys.
