Resetting Camera Position
nrunge1
Our instructors would like the cameras to reset to their default positions prior to the start of class. We use TMS for scheduling.
I understand that I could use the API and schedule the reset commands to be issued from a remote server at the same intervals that class starts.
I'm just curious if there is a better way.
Patrick Sparkman
Using the Configuration Template feature within TMS is one method, create a template that would recall the preset that is set to run at the time specified.  Another method is to use the Standby WakeupAction option, set Standby Delay to 1 minute so the endpoint goes into standby, when it is brought out of standby by either the user or an incoming call, it defaults to the selected camera preset.
