SIP Call with Tandberg C40
SchurmanRyan
I have a Cisco Tandberg C40 codec and have been placing H.323 calls to an organization without any problems.  The organization is now making changes and requiring that I connect to them with their new SIP address.  When I try to connect, it immediately says the call could not be connected.  What are the requirements to place a SIP call with the Tandberg C40?
17 Replies 17
FYI,
I spoke to Cisco and was able to get the release keys for one of the codecs and then upgrade the firmware to TC7.3.11.c1479a9 which resolved the issue, now I am able to connect calls with Cisco WebEx using CMR without any issues.
Thank you.
Glad it worked. This is a pretty good process for most issues: upgrade to latest software and then see if any issues remain.
Jerry
Thank you for your feedback, I was successfully able to get the release keys for the codec so that I could upgrade to the latest firmware which fixed the issue. I think the Tandberg codec's which are running earlier firmware versions are not compatible with Cisco WebEx CMR.
