01-14-2019 05:31 AM - edited 03-18-2019 02:34 PM
Hi all,
I'm having an issue with this system with regard to keeping H323 settings. Originally the system was registering to CUCM but on every restart, the system loses the H323 settings and shows a Status of Inactive. From what I can tell, it enables SIP by default (we don't use that anymore) and turns off H323. Does that just mean it's going to factory? I can manually configure it for H323 and it will register, but only for that current session. What should I be looking for? I've played around with Provisioning.
Currently running software version ce 9.4.0 ...4505.
Solved! Go to Solution.
01-14-2019 03:14 PM - edited 01-14-2019 03:31 PM
It sounds very much like the device is still being provisioned by your CUCM. Have you removed the device from CUCM so that it doesn't see the endpoint and then re-configure it? Do you have anything else on site that may be putting a configuration template on the device (Cisco Prime, Cisco TMS, etc)?
The other option is that someone may have turned the persistency mode on on the endpoint, so the endpoint reverts back to a defined set of settings on a restart
01-14-2019 05:58 AM
Hello Alwin,
If you are provisioning through CUCM you will not be able to use the H323 settings.
Its mentioned in release notes-
So if you wanted to use both H323 and SIP, please turn off the provisioning mode and configure the SIP proxy as CUCM and it will not change the config for H323.
Please rate if it is helpful...
01-14-2019 06:01 AM
I'm not using CUCM and we don't want to. I just want to use H323 but it seems the system is enabling SIP by default.
01-14-2019 06:03 AM
h.323 is an old protocol and should not be used on new systems. Use SIP instead.
Even if you make it work it won't be probably supported by Cisco.
01-14-2019 06:04 AM
Thanks. It's a DoD sponsored network so I don't have any choice there.
01-14-2019 06:17 AM
Alwin,
Make sure under Provisioning, within the codecs webpage, that you set the mode to "Off".
Justin
01-14-2019 06:19 AM
I do, every time. But when it restarts 'Auto' is turned back on.
01-14-2019 06:33 AM
01-14-2019 06:47 AM
No luck.
Provisioning set to 'Off'. CDP, SIP, and Voice VLAN are Disabled. H323 is enabled and manually configured and it registers. However, upon a restart...everything is undone.
01-14-2019 06:56 AM
Hello Alwin,
Try downloading the same software from cisco.com and perform a software upgrade image with same and again try.
Sometimes re-imaging fixes the issue.
Thanks.
03-29-2019 04:53 AM
