04-03-2017 05:36 AM - edited 03-18-2019 12:57 PM
Hi all,
I would like some help to start cisco telepresence installation. Where to start from & things to look out for while installing & what are the products to be installed.Appreciate your help in advance.
04-03-2017 07:27 AM
You might provide some more info, e.g.:
What are you trying to achieve?
What equipment do you have now?
What kind of network are you working with?
What locations (internal/external) are you looking to connect to?
04-03-2017 10:24 PM
Thank you for your replies.
What are you trying to achieve? Complete Telepresence Installation
What equipment do you have now? I am not sure what is required. I do have the BOQ but things are going above my head regarding this.
CTS-SX80-K9 | Cisco SX80 Codec kit |
CON-SCTN-CTSSX80 | SMARTCAREVID 8X5XNBD Cisco SX80 Codec kit |
PWR-CORD-UK-A | Pwr Cord UK 1.8m Black YP-61 To YC-12 |
LIC-CE-CRYPTO-K9 | License key to activate sw encryption module |
LIC-SX80-MS | SX80 MultiSite Software Option |
SW-S52020-CE8-K9 | SW Image for SX80, MX700, MX800 |
CTS-SX80CODEC | Cisco SX80 Codec |
CTS-SX80-RACKEARS- | SX80 rack ears - for auto expand only |
CTS-SPKER-TRACK60 | Cisco TelePresence Speaker Track 60 Kit |
CON-SCTN-CTSSPKER | SMARTCAREVID 8X5XNBD Cisco TelePresence Speaker Track 60 Kit |
CAB-PWR-ST-SHORT- | Two 12V power cables (0.45m & 0.2m) for SpeakerTrack 60 |
CTS-ST-ARR60-WMK- | Wall Mount Kit for Speaker Track 60 Microphone Array |
CTS-CAM-P60+ | Cisco TelePresence Precision 60 Camera - auto expand only |
CTS-ST-INT-PLATE- | Interface plate CAM-P60 to Speaker Track 60 |
CAB-ETH-ST-SHORT- | Two Ethernet cables (0.35m & 0.2m) for SpeakerTrack 60 |
PWR-12VDC-84W- | Power supply 12VDC 84W |
CTS-ST-ARRAY60+ | Speaker Track 60 Microphone Array |
CTI-410V-VTS-K9 | Cisco Multiparty Media 410v Server |
VMW-VS5-410V-K9 | Embedded License, Cisco TelePresence Virt. SW 5.x |
CAB-9K10A-UK | Power Cord, 250VAC 10A BS1363 Plug (13 A fuse), UK |
VMW-VS5-410V-SNS | Cisco TelePresence Virt. SW 5.x SnS |
VTS-SW-4X | Media (no lic) for Cisco TelePresence Svr Virt. Machine 4.x |
CIT3-MRAID12G | Cisco 12G SAS Modular Raid Controller |
CIT3-A03-D300GA2 | 300GB 6Gb SAS 10K RPM SFF HDD/hot plug/drive sled mounted |
CIT3-CPU-E52690D | 2.60 GHz E5-2690 v3/135W 12C/30MB Cache/DDR4 2133MHz |
CIT3-PSU1-770W | 770W AC Hot-Plug Power Supply for 1U C-Series Rack Server |
CIT3-MR-1X081RU-A | 8GB DDR4-2133-MHz RDIMM/PC4-17000/single rank/x4/1.2v |
R2XX-RAID1 | Enable RAID 1 Setting |
R-VTS-K9 | Cisco VM Telepresence Server |
SW-VTS-V4.X-K9 | Software Image for Virtual TelePresence Server |
L-VTS-BASE-PAK | PAK PID for Config Use Only |
L-VTS-K9 | Cisco VM TelePresence Server Release Key |
L-AES-VTS-K9 | AES and HTTPS option for VTS |
TP-SMP-K9 | Cisco TelePresence Shared Multiparty |
LIC-VMCNDTR-PMP-PK | PAK for virtual Conductor |
SW-CDTR-4.X-PMP-K9 | Cisco TelePresence Conductor base software image v4.x |
LIC-CNDTR-PMP-B30 | Conductor license, support up to 30 bridges |
LIC-CNDR-PMP-C2400 | Conductor 2400 call sessions license |
LIC-CNDTR-PMP-CL | Conductor clustering support |
LIC-CNDTR-PMP-K9 | Conductor License for Base Encrypted Software Image |
LIC-TMS-PMP-PAK | TMS PAK for Configuration Use |
LIC-TMS-APL-S80100 | TMS Serial Number included with Base Software |
SW-TMS-15.X-K9 | TMS Base Software Image Version 15.X |
LIC-TMS-25-PMP | Cisco TMS - Additional 25 Direct Managed Systems |
LIC-EXPE-PMP-PAK | Expressway Series, Expressway-E PAK |
LIC-EXP-MSFT-PMP | Microsoft Interoperability Option |
LIC-TMS-EX25-PMP | TMS Exchange integration for 25 Systems |
LIC-TMS-10-INCL | Cisco TMS - included 10 System License |
LIC-SMP-STARTERKIT | Shared MP Starter Kit inc Conductor & TMS with 25 devices |
CUWL-11X-K9 | Unified Workspace Licensing v. 11.x |
NEW-UWL-11X-PRO | New CUWL Professional Edition 11.x User, 1 User |
NEW-UWL-11X-STD | New CUWL Standard Edition 11.x User, 1 User |
NEW-UWL | New or Migration users for a new CUWL Deployment |
UCAPPS-SW-11.X-K9 | Version 11.x Software Kit |
LIC-EXP-E-PAK | Expressway Series, Expressway-E PAK |
WBXMTSVR-UWL-K9 | Webex Meetings Server 2.x Software Kit |
WBXMTSVR2-UWLUSRK9 | WebEx Meetings Server 2.x Users |
IPC8-CLIENT-UWL | IP Communicator 8.x for CUWL only |
JABBER-TABLET | Jabber for iPad and Android Tablet |
JAB-IPH-CLNT-UWL | Jabber for iPhone CUWL Only |
JAB-ADR-RTU | Jabber for Android Right to Use |
VXME-WINDOWS-UWL | Cisco VXME for Windows for CUWL |
SME-11-UWL | Session Manager 11.0 Auto-expanding user for licensing |
CUCILYNC-CLNT-UWL | Cisco Unified Comm Integration for Lync for CUWL only |
UCM-11X-UWL-PRO | UC Manager 11.x CUWL PRO Users |
LIC-TP-PMP-USER | 1 XC PMP User License |
JABBER-DESKTOP | Jabber for Desktop for PC and Mac |
CUCILYNC-UWL-RTU | CUCILYNC UWL Right to Use Certificate |
LIC-EXP-E | Enable Expressway-E Feature Set |
JABBER-SDK | Jabber Software Development Kit |
JABBER-DSK-K9-RTU | Jabber for Desktop Right to Use |
UWL-11X-STD | CUWL Standard 11.x Users - Service Use Only |
CIPC-UWL-RTU | CIPC UWL Right to Use Certificate |
JAB-SDK-K9-RTU | Jabber Software Development Kit RTU |
UWL-11X-PRO | CUWL Professional 11.x Users - Service Use Only |
UWL-11X-PAK | CUWL 11.x PAK |
JAB-IPH-RTU | Jabber for iPhone Right to Use |
VXME-LINUX-K9-RTU | VXME for SUSE Linux Right to Use |
LIC-EXP-SERIES | Enable Expressway Series Feature Set |
UCM-11X-UWL-STD | UC Manager 11.x CUWL STD Users |
UCXN-11X-UWL-PRO | Unity Connection 11.x CUWL PRO Users |
VXME-LINUX-UWL | Cisco VXME for SUSE Linux for CUWL |
JABBER-TABLET-RTU | Jabber for Tablet Right to Use |
JAB-ADR-CLNT-UWL | Jabber for Android CUWL Only |
LIC-EXP-TURN | Enable TURN Relay Option |
LIC-EXP-RMS-PMP | RMS Licensing included with PMP & SMP |
LIC-EXP-AN | Enable Advanced Networking Option |
EXPWY-VE-C-K9 | Cisco Expressway-C Server, Virtual Edition |
LIC-EXP-GW | Enable GW Feature (H323-SIP) |
UCXN-11X-SC-PORTS | Unity Connection 11.x SpeechConnect Ports |
SW-EXP-8.X-K9 | Software Image for Expressway with Encryption, Version X8 |
EXPWY-VE-E-K9 | Cisco Expressway-E Server, Virtual Edition |
LIC-SW-EXP-K9 | License Key Software Encrypted |
VXME-WIN-K9-RTU | VXME for Windows Right to Use |
EXPWY-C-BDL-K9= | Expressway-C and Expressway-E Appliance Bundle Spare |
EXP-SECBZL | Security Bezel for CE1100 |
EXP-TPM2-001 | Trusted Platform Module 1.2 for EXP (SPI-based) |
EXP-N2XX-AIPCI01 | Intel X520 Dual Port 10Gb SFP+ Adapter |
EXP-HDD1TI2F212 | 1TB SAS 7.2K RPM 3.5 inch HDD/hot plug/drive sled mounted |
SW-EXPWY-8.X-K9 | Software Image for Expressway with Encryption, Version X8 |
LIC-EXP-BASE-K9 | License Key Software Encrypted |
EXP-CPU-E52637D | 3.50 GHz E5-2637 v3/135W 4C/15MB Cache/DDR4 2133MHz |
EXP-MRAID12G-1GB | 1GB Cache Module |
EXP-MRAID12G | Cisco 12G SAS Modular Raid Controller |
EXP-SD-32G-S | 32GB SD Card for UCS servers |
EXP-MR-1X162RU-A | 16GB DDR4-2133-MHz RDIMM/PC4-17000/dual rank/x4/1.2v |
EXP-PSU1-770W | 770W AC Hot-Plug Power Supply for 1U C-Series Rack Server |
LIC-EXP-RMS= | Spare Rich Media Session for Expressway Series |
CON-SCTN-LICEXPRM | SMARTCAREVID 8X5XNBD Expressway Rich Media Session |
CON-CCESW-MSFTCRM | CS ESW ICME Microsoft CRM Conn. Lic |
R-VMCNDTRM-K9 | Mid-market (Select) Virtual TP Conductor - 50 Call Sessions |
SW-CNDTR-V4.X-K9 | Cisco TelePresence Conductor base software image v4.x |
LIC-CNDTR-B30 | Conductor license, support up to 30 conference bridges |
LIC-CNDTR-CL | Conductor clustering support |
LIC-VMCNDTR-PAK | PAK for virtual Conductor |
LIC-SW-VMCNDTR-K9 | Software Release Key for Virtual Conductor |
LIC-CNDTR-C50 | Conductor 50 call sessions license |
CTI-CNDTR-K9-RF | Encrypted Conductor spare REMANUFACTURED |
CON-PAMU-VCS-300 | PC ADV SW SUPP+UPGR VCS 300 Add Non-traversal Ntwk Calls |
CON-SW-VCSE-50 | SMARTNET NO RMA,Video Communication Server - 50 Traversal Ca |
L-VCS-PAK | VCS Licenses PAK PIDs |
L-VCS-50 | Order L-VCS-PAK for E-dlvry of 50 VCS non-traversal calls |
L-VCS-OCS | VCS MSFT Interoperability |
L-VCS-FINDME | Order L-VCS-PAK for E-dlvry of VCS FindMe application |
L-VCS-DI | VCS Advanced Networking |
L-VCS-DEVPROV | Order L-VCS-PAK forE-dlvryof VCS Enable Device Provisioning |
CON-SCTN-CTI-410V | SMARTCAREVID 8X5XNBD Cisco Multiparty Media 410v Server |
CON-ECMU-RVTSK9 | SWSS UPGRADES Cisco VM Telepresence Server |
CON-ECMU-TPSMPK9 | SWSS UPGRADES Cisco TelePresence Shared Multiparty |
CON-ECMU-STARTKIT | SWSS UPGRADES Shared MP Starter Kit inc Conductor TMS |
CON-ECMU-CUW1LXK9 | SWSS UPGRADES Unified Workspace Licensing v. 11.x |
CON-ECMU-UWL11XS1 | SWSS UPGRADES CUWL Standard 11.x Users - Service Use O |
CON-ECMU-UWL11XPR | SWSS UPGRADES CUWL Professional 11.x Users - Service U |
CON-SCTN-EXPWYCBK | SMARTCAREVID 8X5XNBD Expressway-C High Performance Appliance |
CON-ECMU-RVMCNDK9 | SWSS UPGRADES Mid-mrkt Virt TelePres Cond-50 Call Ses |
CON-SCTN-CTCNDTRK | SMARTCAREVID 8X5XNBD Cisco TelePresence Conductor incl 30MCU |
CON-SCTN-LVCSPAK | SMARTCAREVID 8X5XNBD VCS Licenses PAK PIDs |
CON-SCTN-LVCS50 | SMARTCAREVID 8X5XNBD VCS 50 Add Non-traversal Ntwk Calls |
CON-SCTN-LICVCSO | SMARTCAREVID 8X5XNBD VCS Microsoft Interoperability |
CON-SCTN-LVCFNDME | SMARTCAREVID 8X5XNBD Video Communication Srvr - FindMe ap |
Then for meeting rooms:
What kind of network are you working with? CUCM v11 on BE6k.
What locations (internal/external) are you looking to connect to? Both. internal & external as we have 4 sites to be connected.
04-04-2017 07:57 AM
Seems that if all that equipment was ordered, someone did some design work. There are installation and configuration guides for all the equipment on the Cisco site. Have you looked at the site Patrick pointed to?
You might get your meeting rooms up and running with the SX80's first as stand alone (not registering to CUCM) so they can be used somewhat and for testing.
04-04-2017 10:17 PM
Yeah i did have a look at the links Patrick posted. But I am still looking for installation & configuration guide. Will check the other links as well now.
SX80's are endpoints registered to CUCM or Telepresence Conductor?
Apologies I am new to Telepresence completely.
04-05-2017 07:34 AM
Endpoints such as the SX80 will register to CUCM. Conductor is used to with the TelePresence Server to offer multiparty conferencing.
Go the Cisco Support and search for the various products within your BOM, and it will take you to the installation, configuration, and deployment guides. You can also use the design guides as they include a high level install/configuration of the different components.
04-04-2017 08:19 AM
I agree with Joe, that isn't a light BOM, someone had to have designed it for you, they should be the person you should reach out to as they'd be the best person to ask. Typically before an order is placed, one should work with their Account Manger and vendor to understand what is being ordered and how it all fits together.
As Joe mentions, take a look a the installation and configuration guides on Cisco.com, there are some guides that cover working solutions where it puts several products together to make the solution work as a whole. For example, the below guides cover CUCM, Conductor, TelePresence Server, and TMS together for a multiparty conferencing solution:
CMR Premises Solution Guide Release 7.0
CMR Premises Deployment Guide Release 7.0 - Primary (for Unified CM)
To get a high level of everything and how they fit together, refer to the design guides I linked to in my previous reply.
04-03-2017 07:47 AM
A good place to start would be the Design Zone for Collaboration, it contains design and configuration guides for collaboration.
