03-30-2015 11:51 PM - edited 03-18-2019 04:16 AM
Hi everyone,
I have a problem with registration between expressway e and sx20 telepresence. We moved our sx20 to different network. We want that sx20 register to expressway e via internet. However, I received registration error from expressway e as unknown domain.
If you want to get some inf. from me about expressway E, I did all mra conf. on expressway E and now all company use vpnless jabber without problem.
Any thoughts?
03-31-2015 08:38 AM
hi,
how did you configure URI setting at moved sx20? maybe there is mistake
04-12-2015 04:34 AM
yes I get same results when I want to register. Do you recommend which I configured wrongly URI of SX20?
04-12-2015 09:30 AM
Take a look at Ruslan's post here, might be the same issue or something similar.
telepresence-endpoint-registering-cucm-through-expressway-internet
04-14-2015 12:58 AM
in my case URI was ok. see Patrick's post below with link to my similar discussion, maybe there you can find solution too
04-10-2015 07:51 AM
hi,
I encountered such problem like you too. I have Jabber for Windows and for Android succesfully connecting through internet but not SX20.
I tried use this document - http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/codec-c-series/tc7/administration-guide/administering-endpoints-running-tc72-on-ucm1051.pdf for configuring SX20 but it didn't work, you can look at p. 48. I can't see any log events after I've configured by this document. when I try configure SIP username in username@domain.com format I can see following error in the log:
2015-04-10T17:30:04+03:00 | tvcs: Event="Registration Rejected" Reason="Unknown domain" Service="SIP" Src-ip="213.108.78.215" Src-port="48150" Protocol="TCP" AOR="sip:domain.com" Contact="<sip:8420@192.168.1.202:5061;transport\=tls>;+sip.instance\="<urn:uuid:743ed821-81dd-56fe-96e6-a9b66e505871>"" Duration="3600" Level="1" UTCTime="2015-04-10 14:30:04,698" |
2015-04-10T17:30:04+03:00 | tvcs: Event="Registration Requested" Service="SIP" Src-ip="213.108.78.215" Src-port="48150" Protocol="TCP" AOR="sip:domain.com" Contact="<sip:8420@192.168.1.202:5061;transport\=tls>;+sip.instance\="<urn:uuid:743ed821-81dd-56fe-96e6-a9b66e505871>"" Duration="3600" Level="1" UTCTime="2015-04-10 14:30:04,698" |
have you get the same events in the log?
