tms license question 15.7 to 15.9 upgrade
KY_
Level 4
Level 4
Hi All
we would like to upgrade tns 15.7 to 15.9 version do we need license for 15.9 or can we upgrade tms 15.9 with our existing license ?
Btw we are using tmsxe 5.7 for mailbox scheduling so we winll need to upgrade it 5.9 also.
thanks
6 Replies 6
Licenses are  for Version 15.X, means it work with any 15.X releases.
Your TMSXE should be on 5.9.
Response Signature
KY_
Level 4
Level 4
Hi Nithin
i can not understand this screenshot if it works without additional license thats ok for me how can i ensure for this before upgrading ?
thanks
License version normally mention 15.X, means its works(Unless you change the serial No) with any minor releases. You can open a licensing TAC case and take  a confirmation.  Use below link >> select  open a case>> select Software licensing .
https://mycase.cloudapps.cisco.com/case
The screenshot shared is From TMSXE 5.9 deployment guide, and it Need TMS 15.9.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwi34uPe3o_yAhXTShUIHYuTC98QFjAAegQIBRAD&url=https%3A%2F%2Fwww.cisco.com%2Fc%2Fdam%2Fen%2Fus%2Ftd%2Fdocs%2Ftelepresence%2Finfrastructure%2Ftmsxe%2Finstall_guide%2F...
Response Signature
In addition to what Nithin has mentioned , please follow upgrade guides.
Cisco TelePresence Management Suite (TMS) - Install and Upgrade Guides - Cisco
Do check for .NET version for 15.9 version and download it and RUN as Administrator prior to execution TMS 15.9 exe.
If you are using external database, keep username and password handy for connecting to external SQL database.
regds,
aman
Aren't TMS products at their end of life and end of sale?
