TMS Replication
jgranata
Hi all,
Somebody know how is the procedure to replicate the config and SQL database between two TMS.
We have one TMS as a primary, and we want the second TMS as a backup (with the services down). We are thinking to do a replication once a week but we don´t know how to do.
We are reading a lot of pdf and installation guide from Cisco / Tandberg, but is impossible to understand very well how to do..... someone have a cookbook (for dummies please!!!)??
Thank you in advance
Juan Granata
2 Accepted Solutions
Justin Ferello
Level 5
Level 5
Juan,
As far as I am aware, TMS does not support replicating the SQL database.  You can however point multiple TMS servers to the same database.
Justin
Thank you,
Justin Ferello
Technical Support Specialist, ScanSource KBZ
Martin Koch
First of all is there a specific reason that you want to use this kind of deployment?
Anyhow your exact deployment wish is not mentioned in the "TMS Server Reduncancy Config guide".
You could also use a sql cluster and two tms connection to it, or if capable, let a virtualization enviroment take care that your TMS does not go down.
To bring a TMS up in case of a failure you need to main parts, the MS SQL DB backup and also copy of the
TMS Agent backup file. I am not aware if you have an IT department, but they might be a good source for help.
short overview what to take care of:
* windows server itself
* services like iss, ms sql, ...
* requiements for tms install (like .net)
* tms installation
* sql db (storing all generic tms stuff)
* opends ldap db (=TMS Agent)
If the directory structure is different you might need to fix the sql file (see sql doc below).
The different ip address / hostname of your spare server might be a problem.
Did you know / read the "TMS Server Reduncancy Config guide"
I would recomend doing so, this shall answer some of your questions or bring up new :-)
Some usefull doc:
http://www.tandberg.com/support/dl.php?id=1350&dir=User_Manuals&fn=Cisco_TMS_Server_Redundancy_Config_Guide_13-0.pdf
http://www.tandberg.com/support/dl.php?id=488&dir=User_Manuals&fn=TANDBERG%20TMS%20Database%20Knowledge%20Tips.pdf
http://www.tandberg.com/support/dl.php?id=1491&dir=Installation_Sheets&fn=Cisco_TMS_Install_Getting_Started_Guide_13-1.pdf
Justin Ferello
Level 5
Level 5
Juan,
Justin
Thank you,
Justin Ferello
Martin Koch
* tms installation
Some usefull doc:
