TMSXE deployment question - server co-residence?
Michael Boscia
Level 4
Level 4
I couldn't seem to find it, although I fully admit I may have missed it in the install guide, I have a question about the feasibility of installing TMSXE on the same server as the TMS application.
I do know that on page 9 the guide says that Cisco "recommends" installing TMSXE on a standalone server.
What I want to know is that it is supported if it is co-resident with TMS (not the SQL server that has the TMS DB on it)?
I get that it isn't recommended, I just need to know if I can get support from TAC or not.
Kjetil Ree
Yes, you will get TAC support.
Kjetil Ree
