07-25-2017 01:25 PM - edited 03-18-2019 01:20 PM
Our vendor recently upgraded one of our Touch10's and now has lights and shade control.
I was wondering is there anyway to create a dial screen that would work well with Blue Jeans?
Bluejeans format is they can be dialed with meetingid.hostcode@199.48.152.152 example: 212121.5555@199.48.152.152
Is there a way to have the screen have 2 entry fields, first for meeting ID, 2nd for optional host code and whatever is entered can be dialed automatically?
They have an android app that does this but would like to get it all in one on the Touch 10 if possible.
Solved! Go to Solution.
07-25-2017 06:33 PM
It's not currently possible to customize the Touch 10 and have it control the codec, the In-Room Controls are for controlling room equipment via a control processor such as Crestron or AMX. The closest workaround would be to use favorites and add the addresses to the directory of the Touch 10..
07-25-2017 06:33 PM
07-26-2017 05:41 AM
Ok, thanks. That's exactly how I do have it set up in the meantime.
