TP Server or MCU
saad alam
Hi we have mix endpoint Couple of  Three Screen Telepresence3000,Some C series and SX20.Now we want Multiconferencing.
Can anyone Advice which option is better to bridge all 12 Sites a) TP server 7010 b)MCU 5320
Saad Alam
5 Replies 5
luchand
The TS 7010 is the way to go if you want to support your CTS 3000 systems - the MCU 5320 will only support a single screen on the CTS 3000; additionally interoperability with the CTS 3000 and the 5300 series MCU is currently not reccomended.
Hi Luc,
Thanks for your responce.
is intreoperateblity is in roadmap or there is additional box for MIX(TP+VC) Scenerio??
Saad
Yes, its something that we're looking to solve moving forward, there's no plans for any additional boxes. However the TS 7010 is still the best bet if you want mulltiple screen support.
Tomonori Taniguchi
If you have multiscreen TelePresence Endpoint, recommend to go with TelePresence Server.
Ageed.
Thanks Saad
