02-27-2017 07:20 AM - edited 03-18-2019 12:49 PM
Hi, trying to add a SX80 to my TMS 12.6, keep getting error
Update Field failed on: Meetings_AcceptScheduling: Object reference not set to an instance of an object.
Is this simply because I'm running an old version of TMS or can I fix with existing version?
Solved! Go to Solution.
02-27-2017 08:23 AM
The oldest version of TMS that supports SX80's (with TC code) is 14.4, and if running CE code you need TMS 15.x.
TMS 12.6 came out in 2010 - time for an upgrade!
02-27-2017 08:23 AM
02-27-2017 08:30 AM
That's what I suspected. The ONLY reason we use TMS is to push the global phonebook on our endpoints (about 12). We can't justify the upgrade cost just for that. I was able to add it by going with the "pre register system" route, but it can't see the name of the unit. I suspect this is all related to the SQL database, with the SX80 having different field names and such.
02-27-2017 11:39 AM
If you're only using TMS to simply be a phone book server to a very few endpoints, why don't you create a local phone book and import that into each of the endpoints. Because you have such a low number, it won't be too hard to manage the XML file of phone book entries and upload a new copy to each endpoint if there ever was an update to it. The local phone book import/export feature is available in the wen interface for endpoints running TC7.3 and later (including CE software) under Configuration > Local Contacts Management.
02-27-2017 12:01 PM
Thanks for the info. We have MXP 3000 units and MXP 6000, and just got a SX80 last week. The 3000 and 6000 have a "Directory" file upload option under "endpoint configuration > files". I just tested it and the file format is .prm which I can't edit in notepad, but if I populate one unit I can download that file and upload on other units. A long process worth doing for now, just a pain when a unit gets moved to a different room or replaced!
