03-08-2012 12:59 AM - edited 03-17-2019 10:53 PM
I have several calls at my VCS that I cannot disconnect (logged in as admin). How can I solve this problem without reboot?
03-08-2012 01:16 AM
I noticed that as well, that's a bug. You should notice that these ghost calls at least don't take a call license.
The only solution I know is to restart or reboot or to wait for an upgrade, ...
03-08-2012 01:29 AM
Hi Martin,
yepp, thats right. But this is a really ugly bug - they confuse our call statistic. Cisco should fix this.
03-08-2012 01:38 AM
Juergen,
what software is your VCS running?
- Andreas
03-08-2012 01:47 AM
Hi Andreas,
X7.0.2
Juergen
03-08-2012 01:57 AM
Juergen,
what type of calls are showing as hanging? Are these interworked calls, B2BUA calls?
Could you post a screenshot perhaps?
Andreas
03-08-2012 03:11 AM
How do you gather your call statistics? TMS, analytics extension, self made, ...?
03-08-2012 03:53 AM
Quick'n Dirty Perl Scripts feeding the information into Nagios. So its not a problem of filtering out the Information only for
the right calls, its only a "cosmetic" based problem.
03-09-2012 02:46 PM
I use the API to monitor the ammoumt of active traversal, local and registrarions ans this works ok for me,
so if you just want to count the amount of calls you can use that as well.
