02-25-2013 07:55 AM - edited 03-18-2019 12:39 AM
i have a time mismatch error while i connect to one of our client side which is on public IP. following logs comes while connecting to perticular public Ip
help me for Same
Feb 25 20:38:16 tvcs: Event="Registration Rejected" Reason="Time difference too large for authentication" Service="H323" Src-ip="210.212.176.35" Src-port="41889" Dst-alias-type="H323" Dst-alias="exampleauth" Protocol="UDP" Level="1" UTCTime="2013-02-25 15:08:16,719"
Feb 25 20:38:16 tvcs: Event="Registration Requested" Service="H323" Src-ip="210.212.176.35" Src-port="41889" Src-alias-type="H323" Src-alias="exampleauth" Protocol="UDP" Level="1" UTCTime="2013-02-25 15:08:16,719"
02-25-2013 04:46 PM
Use an NTP on the VCS and on the Endpoint.
If you think you are using one, check the status of the NTP and that there is no firewall blocking someting.
02-25-2013 09:39 PM
Sir We dont have NTP server in our office. but will it really affect by using NTP ? because we are able to dial on different Public IP except this perticular Single Public IP(115.111.249.140). In Client side they are also uses VCS. and same error occured from their end. followings are error logs.
Feb 25 17:48:58 tvcs: Event="Call Rejected" Service="H323" Src-ip="115.111.249.140" Src-port="15372" Src-alias-type="H323" Src-alias="TCS-HD-Bridge" Dst-alias-type="H323" Dst-alias="0768@210.212.176.58" Call-serial-number="880e4c24-7f45-11e2-8047-0010f32379c6" Tag="50bd2a74-7f4a-11e2-b344-0010f3249666" Protocol="TCP" Response-code="Not Found" Level="1" UTCTime="2013-02-25 12:18:58,686"
Feb 25 17:48:58 tvcs: Event="Search Completed" Service="H323" Src-alias-type="H323" Src-alias="TCS-HD-Bridge" Dst-alias-type="H323" Dst-alias="0768@210.212.176.58" Call-serial-number="880e4c24-7f45-11e2-8047-0010f32379c6" Tag="50bd2a74-7f4a-11e2-b344-0010f3249666" Detail="found:FALSE, searchtype:Setup" Level="1" UTCTime="2013-02-25 12:18:58,685"
Feb 25 17:48:58 tvcs: Event="Search Attempted" Service="H323" Src-alias-type="H323" Src-alias="TCS-HD-Bridge" Dst-alias-type="H323" Dst-alias="0768@210.212.176.58" Call-serial-number="880e4c24-7f45-11e2-8047-0010f32379c6" Tag="50bd2a74-7f4a-11e2-b344-0010f3249666" Detail="searchtype:Setup" Level="1" UTCTime="2013-02-25 12:18:58,683"
Feb 25 17:48:58 tvcs: Event="Call Attempted" Service="H323" Src-ip="210.212.176.58" Src-port="15746" Src-alias-type="H323" Src-alias="TCS-HD-Bridge" Dst-alias-type="H323" Dst-alias="0768@210.212.176.58" Call-serial-number="880e4c24-7f45-11e2-8047-0010f32379c6" Tag="50bd2a74-7f4a-11e2-b344-0010f3249666" Protocol="TCP" Auth="YES" Level="1" UTCTime="2013-02-25 12:18:58,682"
Feb 25 17:48:58 licensemanager: Level="INFO" Detail="License granted" local_call_id="880e4c24-7f45-11e2-8047-0010f32379c6" lic_type="nontraversal" UTCTime="2013-02-25 12:18:58,678"
Feb 25 17:48:58 tvcs: Event="Search Attempted" Service="H323" Src-alias-type="H323" Src-alias="TCS-HD-Bridge" Dst-alias-type="H323" Dst-alias="0768@210.212.176.58" Call-serial-number="880e4c24-7f45-11e2-8047-0010f32379c6" Tag="50bd2a74-7f4a-11e2-b344-0010f3249666" Detail="searchtype:Setup" Level="1" UTCTime="2013-02-25 12:18:58,666"
Feb 25 17:48:58 tvcs: Event="Call Attempted" Service="H323" Src-ip="115.111.249.140" Src-port="15372" Src-alias-type="H323" Src-alias="TCS-HD-Bridge" Dst-alias-type="H323" Dst-alias="0768@210.212.176.58" Call-serial-number="880e4c24-7f45-11e2-8047-0010f32379c6" Tag="50bd2a74-7f4a-11e2-b344-0010f3249666" Protocol="TCP" Auth="YES" Level="1" UTCTime="2013-02-25 12:18:58,666"
Feb 25 17:48:19 tvcs: Event="Registration Rejected" Reason="Time difference too large for authentication" Service="H323" Src-ip="210.212.176.35" Src-port="40818" Dst-alias-type="H323" Dst-alias="exampleauth" Protocol="UDP" Level="1" UTCTime="2013-02-25 12:18:19,397"
Feb 25 17:48:19 tvcs: Event="Registration Requested" Service="H323" Src-ip="210.212.176.35" Src-port="40818" Src-alias-type="H323" Src-alias="exampleauth" Protocol="UDP" Level="1" UTCTime="2013-02-25 12:18:19,397"
Feb 25 17:48:01 tvcs: Event="Call Rejected" Service="H323" Src-ip="115.111.249.140" Src-port="15369" Src-alias-type="H323" Src-alias="TCS-HD-Bridge" Dst-ip="210.212.176.58" Call-serial-number="663ca708-7f45-11e2-b5aa-0010f32379c6" Tag="2ee86652-7f4a-11e2-a5c6-0010f3249666" Protocol="TCP" Response-code="Not Found" Level="1" UTCTime="2013-02-25 12:18:01,933"
Feb 25 17:48:01 tvcs: Event="Search Completed" Service="H323" Src-alias-type="H323" Src-alias="TCS-HD-Bridge" Dst-ip="210.212.176.58" Call-serial-number="663ca708-7f45-11e2-b5aa-0010f32379c6" Tag="2ee86652-7f4a-11e2-a5c6-0010f3249666" Detail="found:FALSE, searchtype:Setup" Level="1" UTCTime="2013-02-25 12:18:01,932"
Feb 25 17:48:01 tvcs: Event="Search Attempted" Service="H323" Src-alias-type="H323" Src-alias="TCS-HD-Bridge" Dst-ip="210.212.176.58" Call-serial-number="663ca708-7f45-11e2-b5aa-0010f32379c6" Tag="2ee86652-7f4a-11e2-a5c6-0010f3249666" Detail="searchtype:Setup" Level="1" UTCTime="2013-02-25 12:18:01,927"
Feb 25 17:48:01 tvcs: Event="Call Attempted" Service="H323" Src-ip="115.111.249.140" Src-port="15369" Src-alias-type="H323" Src-alias="TCS-HD-Bridge" Dst-ip="210.212.176.58" Call-serial-number="663ca708-7f45-11e2-b5aa-0010f32379c6" Tag="2ee86652-7f4a-11e2-a5c6-0010f3249666" Protocol="TCP" Auth="YES" Level="1" UTCTime="2013-02-25 12:18:01,927"
