When trying to integrate Webex server with TMS "Unable To Get Conference Meeting Types From WebEx Server"
gujiguy2642
I have following questions regarding it :
  • •1.       Is there a user page where a user can edit their profile to update their webex username and password?
  • •2.       Is there a way to set the webex username and password using a batch file?
mahkrish
Level 3
Level 3
Below are the steps to configure webex details.
You will need  to get a webex permanent account which will work to integrate with TMS.
Once the account is available you can configure TMS to connect the WebEx server and use it to include WebEx conference.
Setting number one:
TMS > Administrative tools > web conference settings > under web conference configuration
Select web conference support type:
Web conference server DNS name:
Site ID for WebEx server:
Partner ID for WebEx server:
Default WebEx password:
Web conference connection status:
Add Web Conference to all conferences: set to YES  or NO
Settings number two:
Once you are able to connect to the WebEx server then you should go to administrative tools > user
administration> users and select the users who will be booking meeting in TMS > edit and enter the
web conference username and web conference password. Each person who is booking the meeting needs to
have an account.
Thanks for your reply !!! I will try it out ...
Thx
