Orf Gelbrich
Task Name
Automate the DNA Center backup and write a file with all the software versions to bacup server and log in SR log file on UCSD.
Description
Workflow input rules example
Prerequisites
Validated on UCSD 6.6
Category
Workflow Task
Components
User Inputs
Output
Result of operation
Installation
  2. Unzip the file on your computer. Should end up with a .WFDX file.
  8. Click "Submit".
Workflow input:
The workflow:
 Outcome in DNAC:
For more information please take a look at work doc.
kingjin
Hi, Orf
Is it possible to output management information of assurance with your method?
Thank you in advance.
