Orf Gelbrich
Task NameMass create VDC(s) / Find VDC Approver Example
Description
  1. Mass create VDC(s) / Find VDC Approver Example
Prerequisites
  1. Tested on 5.1
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
Many thanks go out to Burton Peake for providing this new custom task and workflow.
Step one update the custom task with the VDC names to clone from (I know not exactly ideal, but we left room for improvement :-)
Execution:
The result after the execution should be a clone of the existing VDC's:
Workflow #2 is fining the approver of a VDC:
Email #1
Email #2
