Orf Gelbrich
Task NameUCSD Remedy Integration
Description
  1. UCSD Remedy Integration
Prerequisites
  1. Tested on 5.2.0.0.A
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
A thank you goes out to Mark Smith:
This is an example of Integration to Remedy CMDB (Atrium).
The API for is Web Services SOAP. Each Remedy installation has the ability to tailor what fields are updated in the CMDB by generating a custom WSDL. First step is to get WSDL file from customer and map UCSD fields to the Remedy fields. Attached UCSD workflows will create a CMDB record (CI) and update a CI when a user changes the memory allocation of the VM. These workflows will not work out of the box because this was for a customer specific WSDL. Also the updating process stores the CI record ID and VM ID as a Linux file on the UCSD appliance. When the update is performed the VM ID is used to lookup the CI record ID so the correct CI is updated. This method was done for a POC and may not be not optimal for production environments. I recommend you use something like SOAP GUI tool to access the WSDL and generating the SOAP XML messages which are stored as structures in the Custom Task (java script).
Example workflow in the distribution(1):
Example workflow in the distribution(2):
Custom Workflow examples:
Java Script Example:
XML Parsing:
The Remedy integration workflow (see link below) parses the SOAP XML message for a particular field in the XML. This is then passed back in a output field.
var response = post.getResponseBodyAsString();
var response = xmlStr;
var is = new ByteArrayInputStream(response.getBytes());
var doc =XMLUtil.parseXMLDocument(is);
var element = XMLUtil.getElementByTagName(doc.getDocumentElement(),"ns0:InstanceID");
  1. logger.addInfo("Instance Id : "+XMLUtil.getText(element));
var instanceId = XMLUtil.getText(element);
matday
Community Member
Thank you for this, it's excellent and exactly what I was looking for!
