UCS Director
Discussions, knowledge articles and more
Field Notice 70545
Activity in UCS Director
ESXI is not boot in UCS C240
Hello All , I am running ESXI 7.0 in cisco UCS C240 Server , Server is shutting down yesterday for physical location migration activity and then server is not boot ESXI when power on again. and not able to see Local Drive in Boot order. Anyone help m...
heaung by Level 1
  • 591 Views
  • 1 replies
Assign-VM-to-User
  Task Name Assigning VM to User Description This task allows for the assignment of a specific VM to a user in UCSD. Prerequisites Add vCenter of version 7 or above to UCSD Category Workflow Components UCSD, VMware vCenter User Inputs Use...
asheksal by Cisco Employee
  • 449 Views
  • 0 replies
Rename VMware VM
  Task Name Rename VMware VM Description This task allows for the Rename VMware VM from UCSD. Prerequisites Add vCenter of version 7 or above to UCSD Category Workflow Components UCSD, VMware vCenter User Inputs VM Selector, vmNewName (Ta...
  • 585 Views
  • 0 replies
Update VMware vCenter
  Task Name Update VMware vCenter Workflow Description This task provides users a facility to update their vCenter(version 7 and above) from UCSD Prerequisites Add vCenter of version 7 or above to UCSD Category Workflow Components VMware U...
  • 598 Views
  • 0 replies
UCS Director Admin Password Reset
I'm trying to find the correct option to reset the Admin password in UCS Director, as it's failing when I try to log in. I can access Shell_Admin and can access the menu to 29) Reset MySQL User password. Is that the same thing?We have a couple of the...
VMware get VM annotation
I am looking to get VM annotation from VMware VM. I see a task name Get VMware VM Details it does provides lot of details but not annotation. Is it possible to modify the script to extract annotations ?  Below is the current script for VMware VM Deta...
ART007 by Level 1
  • 729 Views
  • 0 replies
Cloupia Script Cook Book
This a very nice document for the task called Cloupia Script: http://www.cisco.com/c/dam/en/us/td/docs/unified_computing/ucs/ucs-director/cloupia-script-cookbook/5-0/CloupiaScript-Cookbook.pdf
UCSD - File Upload example (Fileupload)
Task NameFile UploadDescription1PrerequisitesTested on 5.4 betaTested on UCSD 6.0 (see side notes)Tested on 6.0.1.1 this does not work (bug is filed)This is part of UCSD 6.5 Alpha and I have tested it. CategoryWorkflowComponentsvSphere 5.xUser Inputs...
Orf Gelbrich by Cisco Employee
  • 10142 Views
  • 22 replies
  • 1 Helpful votes
Powershell agent replaces double quotes with single
Dear Experts, I have a XML string which is result of one of the previous task. XML string looks like below.$o = "<?xml version='1.0'?><Objects><Object Type='System.Boolean'>True</Object></Objects>"and I am using Select-Xml -Content $o -XPath '//Objec...
KAKA_2 by Level 1
  • 1369 Views
  • 0 replies
Share your Expertise
Level up by answering questions in your area of expertise.
