ā12-23-2015 03:39 AM - last edited on ā03-25-2019 09:55 PM by ciscomoderator
I have configured BE6KS for data and voice users and it is working fine.
On my config issue is in router when i give a command of debug isdn q931 and remote monitor to check call logs but given this command i am not able to see the logs is there some issue with my configuration.
please find the attachment of running config for BE6KS.
ā12-23-2015 04:00 AM
Hi Laxmi,
Did u enable terminal monitor on router ?
regds,
aman
ā12-23-2015 04:31 AM
Hi Aman,
Yes i enable terminal monitor on router not able to see the call logs.
ā12-23-2015 04:49 AM
Is E1 0/0/0 controller UP ?
can u share show isdn status and show controller e1 0/0/0?
regds,
aman
ā12-23-2015 04:57 AM
ā12-23-2015 05:35 AM
Hi Laxmi,
Do u get any command like no logging monitor ?
regds,
aman
ā12-23-2015 06:06 AM
Hi LAxmi,
I checked the attached router config and u have issued no logging monitor.
hostname EvolvenceRTR_IND
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 1000000
no logging console
no logging monitor
can u make it logging monitor and check?
http://www.cisco.com/c/en/us/td/docs/ios/12_2/debug/command/reference/122debug/dbfintro.html#wp1017129
regds,
aman
ā12-24-2015 02:36 AM
Hi Aman,
It is possible after a week only Christmas holiday is there.
I will check and let you know.
Thanks for your input.
ā12-27-2015 07:46 PM
ā12-27-2015 08:12 PM
Hi Aman,
yes now it's showing the calling party and the details.
As this site is very small and they are having only 7 users as you can check with configuration in show running command.
Is there any thing I can do more here as this site is good to learning me.
Does you have any document from where I can learn step by step configuration of cucm as I am since aware the theoretical knowledge on cum but practical hands on I don't have to much.
Once again thanks for the same please do share document.
Please find the attached latest file.
ā12-27-2015 11:23 PM
Hi Laxmi,
you can refer the links
http://brezular.com/2014/01/13/voip-home-lab-part-1-8-cisco-unified-communication-manager-8-5-1-configuration/
regds,
aman
ā12-28-2015 12:35 AM
Hi Aman,
Thanks for the document shared I gone through it was good document for the basic configuration while initial starting the configuration.
Once again thanks for the reply and document.
+five
ā12-28-2015 12:42 AM
Hi Aman,
Forget to ask you one question in CUCM for ISD dialing by default 15 second time was there and now it change to 5 second but while dialing ISD still it is taken same 15 second time.
How can I change it to less time please share your suggestion.
Laxminarayan
ā12-28-2015 01:06 AM
https://supportforums.cisco.com/discussion/11039161/t302-timer
regds,
aman
ā01-04-2016 07:51 AM
Hi Laxmi,
you can also refer the link
http://www.learncisco.net/courses/cucm-basics/cucm-basic-settings/starting-cucm-services.html
regds,
aman
