CallManager 8.X and BlackBerry interoperability
raziel78kain
Level 2
Level 2
Hello.
What are the minimum hardware/software requirements to get the interoperability among a CallManager 8.X (with the "usual" SCCP phones registered on it) and some BlackBerry phones?
If we extend the question to a complete UC 8.X system (Unity Connectiom, IPCC, Presence, ...), how do the requirements above change?
Thanks and regards.
Joseph Martini
There are some tools that may be helpful when trying to do capacity planning: http://tools.cisco.com/cucst/faces/newSol.jsp?create=1.  Alternatively the SRND has capacity conciderations to help plan this along with looking at the data sheets for certain server models will contain information about how many phones, CTI ports, etc are supported.
joemar2,
thanks for your answer.
But I would like to know, for example, if and when I need a CUMA, and BES (BlackBerry Enterprise Server) with a MDS.
Moreover, is there a configuration example related to these two scenarios (CUCM only (if applicable), and CUCM + CUMA + BES)?
Thanks and regards.
