Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco ATA 191 unregistered
akram.root
Level 4
Level 4
Hello all,
I have a cisco ATA 191 configured on cucm 11.5 , but the ATA is not Registered on cucm and i can't accees via web browser
but i can ping to it .
 I found on syslog RTMT that : device unregistered reason =13
Could you help me please
Best regards
The problem of ATA is Registered after reset
Best regards
6 Replies 6
akram.root
Level 4
Level 4
Thank you for your reply , i verified the CPU is good.
Best regards
That's just one of the multiple things listed as possibilities to why this would happen. Have you ruled out any of the others?
Response Signature
I can ping to ATA but i can't access to it  via network.
Best regards
And that tells you what? Sort out any network related communications issues and see if that makes any difference. Just posting this somewhat meaningless random information is not very helpful in making this go anywhere closer to a solution.
Response Signature
Best regards
