06-24-2011 10:17 AM - edited 03-19-2019 03:10 AM
I have a quick question: if we use CUCILync 8.5, do we still need CUPS to see the availability status of the phones, even if a user has only a Cisco phone, and not Lync?
TIA and regards.
Solved! Go to Solution.
06-27-2011 09:12 AM
No because User A in your example is not running CUCILync to feed their phone's status into the Lync client. Note that a CUP server is never used with CUCILync. The only time you would use a CUP server is if you want to perform a CSTA gateway integration to the Lync servers instead. You would not typically deploy both configurations; either CUCILync or the server-side integration.
06-24-2011 11:13 AM
No. CUCILync will take CTI control over the phone and feed the on/off-hook status to the Lync client.
06-25-2011 01:41 AM
Jonathan,
I don't know if I have correctly explained my problem, so I make a simple example:
User A
Cisco 7940
User B
Cisco 7960
Lync/CUCILync
So, only User B has Lync/CUCILync.
Can User B see the status of User A by Lync/CUCILync without using CUPS? That is, do I need only CUCM + Lync to see that status?
Regards.
06-27-2011 09:12 AM
06-28-2011 05:22 AM
Thanks for your answer, Jonathan!
Regards.
