CUDAC CUBAC CUEAC seat license
Roman Rodichev
Level 7
Level 7
- Install client software on three PCs
- Create one CUxAC login account on the server
- Three people login to CUxAC on three PCs at different times with the same login account
- There are never two people logged in at the same time
Will one CUxAC seat license suffice in this scenario?
William Bell
From this link:
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6789/ps7046/ps7282/product_data_sheet0900aecd805e6a5f.html
The licensing appears to follow a concurrent connection model. Which suggests, that you only need one seat license in your scenario. From the link above:
Ordering Information
You  must order a Cisco Unified Business Attendant Console license for each  concurrent operator login. A maximum of six concurrent operator client  logins are supported per Cisco Unified Business Attendant Console  server. Example: If you need six attendant consoles logged into the  server at the same time, you should order six licenses.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
William Bell
From this link:
HTH.
Bill
Thanks Bill!
