07-23-2016 05:34 PM - edited 03-19-2019 11:23 AM
I installed cucm 11. I want to register Voip provider with SIP Trunk. (register mode)
How can i do over CCM ?
Best regards
Ali
07-23-2016 08:22 PM
You can't. CUCM only supports line-side SIP registration.
You'll need to use Cisco Unified Border Element, either on a physical router or in a virtual machine using via the Cloud Services Router.
07-26-2016 08:05 AM
Hi Jonathan,
thanks for help
İ will try
09-05-2016 06:04 AM
Thanks Jonathan. I'm going down that route too- are there any docs on configuring sipgate trunks with a home lab CUCM/CSR1000v? or have you any tips?
