IP Phone login with with PC login from LDAP
muazam ali
Dear Team,
i would like to know is it possible that when i am logging in to my pc with my LDAP password then my IP phone should also gets signed in as soon as i put LDAP password in my PC
Leszek Wojnarski
Just to clarify. You'd like you desk phone to login to Extension Mobility after you login to your PC?
If yes, then there is no such a feature on CUCM. Technically this can be done with some 3rd party applications - I don't know if any companies offer such solution. But there needs to be a mapping somewhere to user <> phone.
Technically it's fairly simple to be done. For example you can add bat script to your PC that would trigger web-access in the background that would open:
http://<CUCMIP>:8080/emapp/EMAppServlet?device=SEP20BBC0DE06D3&userid=<USERID>&seq=<USERPIN>
so this will login user using provided details to a specific phone listed in the URL.
Leszek
Yes, there are already some 3rd party solutions for this
http://docwiki.cisco.com/wiki/UC_3rd_party_vendors#VoIP_Integration
java
if this helps, please rate
