02-04-2008
02:10 AM
- last edited on
03-25-2019
09:26 PM
by
ciscomoderator
As I know, ccx call recording is only "on-demand recording"; that is an agent or supervisor have to click "record" to start recording for a call.
is there a way to make full recording (record all calls carried out) without introducing a third-party solution like speechlog?
thank you a lot in advance
I shall be waiting for ur answer
02-04-2008 07:12 PM
Nasser,
I am afraid you will have to rely on third party and cisco solution is there for emergency use only and its not meant for quality monitoring or recording.
There are some low cost solutions on the net or you can go with expensive solutions like witness, verint, call rex etc.
Please rate helpful posts.
Good luck,
Abdulbaseer.
02-05-2008 05:32 AM
Well, it seems that can be done specifically with CCX 5.0 by deploying Quality Manager QM, which requires a dedicated license
waiting for any contribution which contains QM implementation
04-07-2008 06:44 AM
You can set up a workflow in Desktop Administration upon answering a call to start recording. I have not tested this, but it seems very logical. The issue then is space.
