MCS 7825I4 to CUCM 8.6
jc.saavedra
Hello.
I´m trying to upgrade CUCM 7.1.5 to CUCM 8.6 into MCS 7825I4.
According the compatibility matrix i need to add 2 MB of RAM more.
MCS 7825
2GB
For   version 8.0(3) or higher, 4 GB strongly recommended, required for 8.6(1)+
My question is, if i buy this memory ram and put into the MCS, the server is supported or loose the guarantee?
Thank you.
thomascollins
Level 3
Level 3
It's still supported.  Technically you're supposed to buy the official Cisco part number from a Cisco reseller, but since those servers are end-of-life, I'm not sure you can still do that.  The part number was MEM-7825-I4-2GB=.  You can probably look for that on the secondary market, or check with your reseller.
thomascollins
Level 3
Level 3
Thank you for the reply.
