NM-CUE module Upgrade
acharyr123
Level 3
Level 3
I am trying to upgrade NM-CUE from current 7.0 to 8.6. Can someone suggest me what is the procedure for the same?
ronpatel
Level 8
Level 8
HI
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel8_6/install/upgrade.html
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
ronpatel
Level 8
Level 8
HI
Ronak Patel
Hi Ronak,
I have downloaded cue-vm-k9.nmx.8.6.1.zip that contains the below files:
1. cue-installer.nmx.8.6.1
2. cue-vm-full-k9.nmx.8.6.1.prt1
3. cue-vm-installer-k9.nmx.8.6.1.prt1
4. cue-vm-k9.nmx.8.6.1.pkg
5. cue-vm-langpack.nmx.8.6.1.pkg
Do you have any document that says the procedure of uploading the files into NM-CUE?
