09-05-2016 05:56 AM - edited 03-19-2019 11:33 AM
I'm trying to configure a SIP trunk (from sipgate) to my Lab CUCM in a virtualised environment. Has anyone got any tips? I'm assuming I'd need to terminate the SIP trunk on a router which I'd hope to virtualise on GNS/UNetLabs.
Any help is appreciated
Cheers
Richard
09-05-2016 06:12 AM
On CUCM you can add a SIP Trunk to a destination device which understand SIP. Below are some example that might help.
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/117300-configure-cube-00.html
https://supportforums.cisco.com/blog/12108326/implementing-sip-gateways-cucm
JB
09-05-2016 07:40 AM
You can have a direct SIP Trunk to an ITSP from CUCM (i.e. without a CUBE) but its not recommended.
Ideally you want an ISR router acting as a CUBE Voice Gateway.
