Unity Connection 8.5 | Prepend Digits to Dialed Extensions overlap with an option in a call handler
aromn
One customer has requested to set up a call handler in Unity Connection 8.5. The call handler should be capable of transfering calls to IP phones by dialing the last 4 digits of the IP phone's extension. The last 4 digits of the extension from all IP phones begin with 12. However, the customer is also requesting to have an option on the same call handler, so that if users would dial 1, the call is transfered to an IP phone
As you can see, there is an overlap between the last 4 digits of all IP phone's extensions, and an option in the call handler. Therefore, if I configure both options in the same call handler, when the users would press 1, Unity Connection will immediately send the call to the extension setup for option 1, even if the user wants to dial the last 4 digits of an IP phone extension
One possible solution would be to change the option in the call handler to transfer the call to an IP phone, to something different than 1. However, the customer wants to have this transfer to be performed when he press option 1
Is there any other possible solution for achieving this?
Thanks in advance
Jaime Valencia
I don't see any problem, just don't check the option to ignore additional input when configuring caller input on digit 1
By default CUC will give you 1500 ms to dial for any other digits before trying to route the call with whatever you dialed.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Hi Java,
I am facing the similar isue where i have internal extensions in the range of 1XXX and 2XXX.
I unchecked the above options but it not taking effect i.e if i dail any extension from the above range i am getting a message that you cannot be transferred to that number.
aromn
Thanks a lot Jaime, I configured this as you explained, tested it, and it work fine
